Old 02-17-2014, 12:46 PM   #1
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Perrin Front Control Arm Braces: Anyone have Experience?
Anyone?
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Old 02-23-2014, 02:09 PM   #2
TouchMyHonda
Vtec Jesus
Old 03-04-2014, 10:41 AM   #3
dp1
driving smoother faster
Drives: Sold
Nobody?
dp1 is offline   Reply With Quote
Old 03-04-2014, 11:21 AM   #4
frslee
Just drive it
Drives: 13' FR-S
frslee is offline   Reply With Quote
Old 03-08-2014, 03:05 PM   #5
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I installed them last spring and they made quite a difference at turn in under braking at the track. Before they were installed the turn in was quite vague under heavy braking.
Edit: I should have noted here that I also installed the Perrin offset control arm bushings at the same time. The comment still holds true, but the control arm bushings played some part. I think the control arm bushings helped more with the turn-in. The control arm braces helped more with the feel under heavy braking just prior to turn-in.
I think these are best used in conjunction with other braces.
Adding a non-hinged strut tower brace like this one
http://passwordjdm.com/PasswordJDM-U...8627C2619.aspx
will help out some. What really made a difference was this chassis brace:
http://www.frsport.com/Carbing-Front...Z_p_52274.html
You can expect more NVH with this one, but it is worth it in my opinion. When the weather warms up I plan to do a full review.
Last edited by Black Tire; 03-10-2014 at 10:45 PM. Reason: Forgot to mention another suspension piece installed at the same time
Old 03-09-2014, 05:03 AM   #6
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Perrin now has a strut tower brace to
http://ft86speedfactory.com/perrin-s...a9711d3054b7e7
Old 03-20-2014, 02:39 AM   #7
koevasi
koevasi's Avatar
Drives: 1
I installed these separately to my offset bushings.
The difference is almost imperceptible. There IS a minute improvement in braking stability.
koevasi is offline   Reply With Quote
Perrin Front Control Arm Braces grodenglaive DIY (Do-It-Yourself) Guides 7 10-29-2014 04:07 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
FS: Perrin Front Control Arm Braces continuecrushing Brakes, Suspension, Chassis 4 06-28-2013 02:21 AM
Perrin front control arm brace whataboutbob Brakes, Suspension, Chassis 2 04-30-2013 03:15 AM
First time traction control off experience Nate219BRZ BRZ First-Gen (2012+) — General Topics 6 08-13-2012 03:35 PM
