Drives: Subaru BrZ Premuim
perrin 2.5 exhaust rattle
Hey guys, i haven't
posted here much but usually stealth and read posts. I understand that the car does rattle when its cold but on my brz the exhaust rattles really loud sometimes when its completely warm, but if i shit to neutral it goes away. Any ideas?
Drives: 2013 black AT, OFT, 4.65
Turn your S pipe. The one that goes before the muffler.
Ok I'll see if that helps, thanks
Drives: 2013 Subaru BRZ MT Limited
If you have the resonated version there could be a spot on the resonator that makes contact with the driveshaft tunnel. Check around the tunnel and if you have any area's that have less than 1/4" to a 1/2" of clearance you need to adjust your front exhaust mount on the back of the transmission.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
I have tons of clearance around my mid pipe, but I'm also running their front pipe so I'm not sure if that helps with alignment or not.
Just installed my 3'' non resonated perrin exhaust leaving q300 behind.
Love the exhaust sound along my Invidia test pipe, motiv overpipe and turbo setup. But there is a nasty rattle noise coming from the exhaust especially on cold start, at low rpm on 1st or 2nd gear is when the rattle starts, sounds like a nasty metal hitting each other just like a beat up car goes, i triple check everything and clearance is good nothing touching, i never had an issue with the q300 on the same setup, its bothering me a lot. |
#8 | |
Sorry to hear about the rattle, since it sounds like you have a complete exhaust installed and you've already checked the catback, try checking the rest of the exhaust, maybe it's the front pipe? You might have to loosten the whole exhaust again to get a little more room.
Thumper
Drives: 2013 FRS
I would say it has to be in the adjustment. Mine's been trouble free for over a year.
Car is gone - parts for sale
#10 | |
Drives: 2014 Limited Subaru BRZ DGM
Let me know what you find. My Perrin 3" is on order. |
#11 | |
Drives: 2013 Subaru BRZ, 2007 V6 Mustang
#12 | |
That will be fine, if you've had it on for a while and haven't heard anything, you are OK. The exhaust really shouldn't be contacting anywhere, or making any strange sounds under any circumstances, unless you hit something! |
#13 |
This is what im having but cold and warm
http://www.ft86club.com/forums/showthread.php?t=33788 Im 90% certain it has to do with the exhaust, i checked everything from over pipe to muffler nothing is touching, its very hard to put a GOpro or any camera under the car to hear whats going on while driving. From what i can tell the sound comes from the middle, exactly where this pipe connects to the invida test pipe images by sniper260687, on Flickr00:04 You can hear it a bit [ame="https://www.youtube.com/watch?v=8M2Q0-QfJsw"]Perrin - YouTube[/ame] 00:08 [ame="https://www.youtube.com/watch?v=TTkX4b8THkI"]Rattle perrin - YouTube[/ame] |
#14 |
Thanks for the vids. To me, it sounds like it's more of an exhaust leak than anything else. If it's happening when the car is sitting still, then it for sure wouldn't be a clearance issue, unless the exhaust is right up against the chassis, or there's something that's loose like a heat shield.
| Exhaust rattle on cold start? | Laurie | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 12-04-2020 07:15 PM |
| Tomei exhaust spring rattle | hotpanda1 | Engine, Exhaust, Transmission | 23 | 07-02-2016 06:00 PM |
| SpeedFactory V1 Exhaust VS perrin exhaust | 21_nola_05 | Engine, Exhaust, Transmission | 18 | 06-19-2015 02:54 PM |
| Perrin Catback Exhaust vs Nameless Performance Exhaust. | vignesh | Engine, Exhaust, Transmission | 201 | 06-05-2013 09:47 PM |
| Exhaust vibration/rattle at cold start? | Foobar | Engine, Exhaust, Transmission | 7 | 04-16-2013 05:15 PM |
