Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > User/Vendor/Sponsor Reviews, Feedback, Comments
Old 02-15-2014, 09:14 PM   #1
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
AVO Breather Tank, caution
I've been raised to never complain about an issue without providing a solution. So here's my review of the AVO Breather Tank.
Reason for purchase:
I have the FBM Stage 2 turbo and wanted a stealth/stock looking breather tank, nothing blingy. I also like that this kit supposedly re-routes oil back into the crankcase for those long track days.
Quality: 4.5/5
I really like the look of the "black box" style tank, fitment and mounting was great. I had to mark down a little due to using plastic npt fittings on the tank itself.
Install: 3/5
Firstly, the install guide itself leaves alot to be desired and geared toward AVO turbo owners. Breather tanks aren't that complicated but terminology and supplied items make it harder than it needs to be. Let alone I had to reverse engineer a product, that was built for my car, because of the next issue.
Packaging: 2/5
Ok. This is where I can't understand why, why, why would you put items in your packaging that you know doesn't fit? The supplied PCV replacement nozzle that goes into the head, doesn't fit, and they've known about it for a while. Not only that but they are slow to send out the part that does fit. Quality assurance failure. I shouldn't have to go to my local car parts store and buy items to "fix" your kit. Never mind that this kit isn't supposed to work with other turbo kits. Notes for this in the solution.
Solution:
Fix your quality assurance. Make sure you never send out the incorrect parts in your packaging, ever. In your product description, please add "Caution, the instructions and parts for this kit is tailored for the AVO Turbo kit, you will need to retrofit this for other turbo kits". Had I known that I would have to go buy a breather filter and heater hose npt adapter to fix your "mistake" I probably wouldn't have bought this. Please fix your instructions to make it more clear. I can tell it was a direct translation from another language.
Note for AVO should you read this. Breather tanks are simple, if you can't get it right then I probably won't buy any more AVO products or condone them to my friends. :sadface:
Ironsquid is offline   Reply With Quote
The Following 2 Users Say Thank You to Ironsquid For This Useful Post:
Draco_PR23 (02-17-2014), jamesm (02-15-2014)
Old 02-17-2014, 06:21 PM   #2
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I got the AVO Breather Tank along with the turbo kit, the block fitting doesn't fit .. I spoke with Paul and I'm just waiting to ship replacement.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Ironsquid (02-17-2014)
Old 02-17-2014, 07:05 PM   #3
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
go to a parts store and grab yourself a 5/8 NTP heater hose adapter, screws right in. Youll need to get a section of 5/8 hose to go with it. Itll smoosh onto the t adapter for the pcv lines like less than 10 bucks
Draco_PR23 (02-17-2014), jamesm (02-17-2014)
Old 02-17-2014, 07:11 PM   #4
Draco_PR23
Fiebru
Draco_PR23's Avatar
Nice, will do that .. thanks!
Current Cars:
Caution – Differential Gear Oil Equivalent Daless2 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 08-18-2015 07:47 PM
Catch Can breather line question protpibe Engine, Exhaust, Transmission 1 01-18-2014 03:20 PM
CAUTION: Drop in Air Filter Install Rabble Engine, Exhaust, Transmission 19 10-04-2013 08:08 PM
CAUTION ..... newbies ..... killer parking stops.... humfrz Scion FR-S / Toyota 86 GT86 General Forum 36 09-21-2013 12:50 PM
Questions on AVO Breather Kit? BenArmstrong Engine, Exhaust, Transmission 7 09-17-2013 03:01 AM
