Drives: Asphalt FR-S
Speedo issues
So I was looking at some 18 x 8.5 wheels and found that it puts the speedo all out of whack:
![]() Is there a way to compensate for this?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Drives: Subaru BRZ Limited
Don't look at your speedo?
No. Geometry is geometry.
If you car about a better match for the speedometer, go with 245/35. If you really want 255, subtract 1 when you look at your speedometer. Of course you are assuming that the speedometer was actually 100% accurate with the stock tires. |
Agreed, I was just curious if this was something that a tune could "sort out"
Drives: FRS
Drives: 13 SWP BRZ Prem
While driving subtract one when going more than 30MPH (assuming it rounds)?
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
get a tire size with the exact same diameter as the stock tires... But make sure they never ever ever wear, because the slightest amount of tire wear even on the stock tires is going to change the speedo readout... air pressure too for that matter... get Nitrogen quick so air pressure is constant.
Drives: Turbo BRZ & Supercharged E90 M3
1 mile per hour off.. seriously?
#10 |
Drives: 13' Subaru BRZ Limited SWP 6MT
#11 | |
No need to be sarcastic, it was an honest question... Obviously tires wear and that alters the accuracy but I was curious if there was a way to minimize the margin of error.
#12 |
It is already very minsized. Plus you are putting less miles on your car, better for you when it comes to warranty.
Never heard of a dealer saying they aren't going to warrant something because mileage isn't Accurate due to tire size putting o n false mileage. |
#13 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
have you checked the accuracy of your speedo on stock tyres? Mine reads high by 5% on the stock setup
#14 |
Drives: 2013 Toyota 86 GTS, Marine Blue
Use a navagation system.
Not the cars one obviously, but one you stick to your windscreen. Or download the 'Tom Tom' app from App Store to test. 2 different brand of navs at 100km/h (cruise control on car) read 95-97 on the navs. So I can only assume the stock car odometer is 4-5% slower than what it says for speeding issues etc. it's reported that on average all car speedos are anywhere between 2-10% out of actual speedo readings to save you if you accidentally go 65 through a camera it's actually 60 or so (according to wheels magazine) Or get an incredibly thin tire, same diameter as stock or become comfortable with going "60" but actually doing 61!! The choice is yours :p Injen Catback, Injen CAI, Borla UEL headers, ecutek tune w/ racerom, alloy pulley kit, Yokohama Neova AD08; 189hp at the wheels best dyno
check out my on-going build here: My blue 86
| The speedo sucks ! | Mikem53 | Scion FR-S / Toyota 86 GT86 General Forum | 69 | 05-21-2015 05:12 AM |
| Any way to mod the speedo MPH reading? | Tromatic | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 06-24-2013 10:34 PM |
| Change dashboard/speedo lighting? | rhysmcinerney | DIY (Do-It-Yourself) Guides | 4 | 03-02-2013 11:35 PM |
| Adjusting Speedo to new tires ? | rikdrt1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 12-16-2012 11:31 AM |
| cruise control and speedo issue.. | tibsy92 | Issues | Warranty | Recalls / TSB | 1 | 10-10-2012 12:21 PM |
