Old 02-12-2014, 09:17 PM   #1
Venator
Venator's Avatar
Drives: Asphalt FR-S
Speedo issues
So I was looking at some 18 x 8.5 wheels and found that it puts the speedo all out of whack:
Is there a way to compensate for this?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 02-12-2014, 09:24 PM   #2
Burrcold
Drives: Subaru BRZ Limited
Don't look at your speedo?
The Following User Says Thank You to Burrcold For This Useful Post:
hotpanda1 (02-14-2014)
Old 02-12-2014, 09:30 PM   #3
jvincent
jvincent's Avatar
No. Geometry is geometry.
If you car about a better match for the speedometer, go with 245/35. If you really want 255, subtract 1 when you look at your speedometer.
Of course you are assuming that the speedometer was actually 100% accurate with the stock tires.
The Following User Says Thank You to jvincent For This Useful Post:
SkAsphalt (02-14-2014)
Old 02-12-2014, 09:31 PM   #4
Venator
Venator's Avatar
Old 02-12-2014, 09:32 PM   #5
Venator
Venator's Avatar
Agreed, I was just curious if this was something that a tune could "sort out"
Old 02-12-2014, 09:50 PM   #6
kidgogeta
Drives: FRS
the tune for my dodge ram takes into account tire and wheel size and adjusts the speedometer accordingly, not sure if there is anything out for the twins
kidgogeta is offline   Reply With Quote
Old 02-12-2014, 10:15 PM   #7
Imrac
Drives: 13 SWP BRZ Prem
While driving subtract one when going more than 30MPH (assuming it rounds)?
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 02-12-2014, 10:42 PM   #8
KONVERTER
KONVERTER's Avatar
get a tire size with the exact same diameter as the stock tires... But make sure they never ever ever wear, because the slightest amount of tire wear even on the stock tires is going to change the speedo readout... air pressure too for that matter... get Nitrogen quick so air pressure is constant.
KONVERTER is offline   Reply With Quote
The Following User Says Thank You to KONVERTER For This Useful Post:
RenaissanceBoy (02-14-2014)
Old 02-12-2014, 11:17 PM   #9
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
1 mile per hour off.. seriously?
h4nh is offline   Reply With Quote
The Following 4 Users Say Thank You to h4nh For This Useful Post:
mwjcyber (02-14-2014), OICU812 (02-13-2014), RenaissanceBoy (02-14-2014), SkAsphalt (02-14-2014)
Old 02-12-2014, 11:55 PM   #10
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
This^
mwjcyber is offline   Reply With Quote
The Following 3 Users Say Thank You to mwjcyber For This Useful Post:
JS86JS (02-14-2014), OICU812 (02-13-2014), tbertran (02-14-2014)
Old 02-13-2014, 12:59 AM   #11
Venator
Venator's Avatar
No need to be sarcastic, it was an honest question... Obviously tires wear and that alters the accuracy but I was curious if there was a way to minimize the margin of error.
Old 02-13-2014, 02:07 AM   #12
KONVERTER
KONVERTER's Avatar
It is already very minsized. Plus you are putting less miles on your car, better for you when it comes to warranty.
Never heard of a dealer saying they aren't going to warrant something because mileage isn't Accurate due to tire size putting o n false mileage.
Old 02-13-2014, 03:23 AM   #13
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
have you checked the accuracy of your speedo on stock tyres? Mine reads high by 5% on the stock setup
JP is offline   Reply With Quote
Old 02-14-2014, 12:25 AM   #14
JS86JS
JS86JS's Avatar
Drives: 2013 Toyota 86 GTS, Marine Blue
Use a navagation system.
Not the cars one obviously, but one you stick to your windscreen. Or download the 'Tom Tom' app from App Store to test.
2 different brand of navs at 100km/h (cruise control on car) read 95-97 on the navs.
So I can only assume the stock car odometer is 4-5% slower than what it says for speeding issues etc.
it's reported that on average all car speedos are anywhere between 2-10% out of actual speedo readings to save you if you accidentally go 65 through a camera it's actually 60 or so (according to wheels magazine)
Or get an incredibly thin tire, same diameter as stock or become comfortable with going "60" but actually doing 61!!
The choice is yours :p
Injen Catback, Injen CAI, Borla UEL headers, ecutek tune w/ racerom, alloy pulley kit, Yokohama Neova AD08; 189hp at the wheels best dyno
check out my on-going build here: My blue 86
JS86JS is offline   Reply With Quote
The speedo sucks ! Mikem53 Scion FR-S / Toyota 86 GT86 General Forum 69 05-21-2015 05:12 AM
Any way to mod the speedo MPH reading? Tromatic Cosmetic Modification (Interior/Exterior/Lighting) 7 06-24-2013 10:34 PM
Change dashboard/speedo lighting? rhysmcinerney DIY (Do-It-Yourself) Guides 4 03-02-2013 11:35 PM
Adjusting Speedo to new tires ? rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 12-16-2012 11:31 AM
cruise control and speedo issue.. tibsy92 Issues | Warranty | Recalls / TSB 1 10-10-2012 12:21 PM
