Old 02-12-2014, 01:40 PM   #1
brn12345
brn12345's Avatar
Individual cylinder timing maps
As much as I have been on the dyno fiddling I never tried to zero out the timing retard that is present in the number 1 and 2 cylinders in high rpms (see picture of cylinder 1 vs 3). I also recently noticed that on some open source E85 maps those tables are all zero'd out. If high octane gas is used, can those be safely zero'd out or is there another reason for the retard in cylinders 1 and 2?
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 02-12-2014, 01:47 PM   #2
jamesm
I've run mine zeroed out for a while now, haven't noticed any ill effects. It supposedly makes for a smoother idle, but I haven't noticed anything in that regard either.
Old 02-12-2014, 01:52 PM   #3
brn12345
brn12345's Avatar
How can it make for a smoother idle if it only impacts high load / high rpm? Are you confusing these with other tables?
Old 02-12-2014, 02:04 PM   #4
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
With high enough octane fuel (ie, race gas) zeroing them out will improve performance. On pump gas it will have the opposite effect as then you will have to make your base timing map more conservative to account for the more knock prone cylinders. It has no effect on idle quality that I'm aware of.
Old 02-12-2014, 02:08 PM   #5
jamesm
I could've sworn I had seen where the OTS map release notes mentioned zeroing it out for a smoother idle. Maybe I'm not remembering correctly...
Old 02-12-2014, 02:18 PM   #6
mad_sb
Drives: 2013 Asphalt FR-S
There is a lot of talk on romraider about that affect as well... even though the tables don't look to be active at idle I've had mine zeroed out on E85 for a long while now. I reduced them by about 1/2 on pump gas AFTER doing my full exchaust, including header.
Old 02-12-2014, 02:34 PM   #7
mad_sb
BTW, the stock mapping pulls timing at lower rpm's as well as upper so that map you are showing has already been modified from the stock rom map.
Old 02-12-2014, 03:15 PM   #8
brn12345
brn12345's Avatar
Ok just zeroed all individual cylinder timing trims on shivs map 1.55 stage 2 el. Will be running a test tomorrow to see potential top end gains. On another note the 1.55 map is a big step up from the 1.3x I was running before!! Very responsive in mid rpms.
Old 02-12-2014, 03:29 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why are those cylinders more knock prone? Is there any way to adjust this on ECUtek?
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-12-2014, 03:59 PM   #10
arghx7
Drives: car
Most engines have some variation between cylinders on knock limit. You can see it with combustion pressure sensors. A lot of it is due to individual differences in air and coolant temperatures or flow that are basically unavoidable.
If you're on E85 or race fuel it might make sense to change those compensations because you may never knock much at those speeds and loads. But on pump gas--do you really want to run spark harder there? You might pick up power from zeroing out the compensations, but you're probably knocking the engine harder. Knock occurs at different levels of severity, rather than a "well it's knocking or it's not knocking" kind of deal. Changing components like exhaust might help reduce knock sensitivity for those cylinders on pump gas, or it might not.
And the knock control system is unreliable at that high of speed--there's too much noise. So I wouldn't go off that. The guys who made those tables probably dialed them in in a lab somewhere.
Are you really sweating those extra couple degrees of timing?
arghx7 is offline   Reply With Quote
Old 02-12-2014, 07:47 PM   #11
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
When i saw last post arghx7 got excited knowing I was going to read and learn something new.
F*cking walking library....
Old 02-13-2014, 01:33 AM   #12
brn12345
brn12345's Avatar
I agree that 2 odd degrees on just two cylinders might not make a world of a difference, but I do have a theory that I want to test out.
1. I have a hunch the stock map pulls timing in the 1/2 cylinders not because they are detonation prone.
2. When I changed to headers I measured the stock header primary's and noticed that 1/2 primaries are shorter than 3/4.
3. I installed Equal length headers.
So my theory is that the timing retard on 1/2 is there for pulse tuning purposes and since I moved to equal length that now the pulses are out of sync. I went ahead and zeroed out the tables and will be testing tonight to see the difference.
Does this make sense or am I just theorizing too much?
Old 02-13-2014, 09:06 AM   #13
u/Josh
Drives: GBS Limited 6MT
This is an interesting thought. At 6000 rpm the engine will rotate through 2 degrees in
6000 rotation/min * (1/60) min/sec * 360 degree/rotation = 36000 degree/sec
2 degrees / (36000 degree/sec) = 55 * 10^-6 seconds
Assuming the speed of sound is close to the speed of sound at sea level, the distance the exhaust pulse would travel in that time:
55*10^-6 seconds * 343 m/s = ~ 2 cm
I am making a lot of huge assumptions about systems that I don't fully understand so this could be way off, but my back of the envelope calculation and basic understanding say your theory is feasible. One thing to note, however, is that if their only goal with that timing table was to match up exhaust pulses then the timing retard should increase linearly with engine speed.
u/Josh is offline   Reply With Quote
Old 02-13-2014, 11:29 AM   #14
arghx7
Drives: car
How would retarded spark change the pulse tuning enough to matter if the exhaust valve opening events are the same?
Can somebody post the stock injection timing and DI/PFI split maps? arghx7 Engine, Exhaust, Transmission 7 09-19-2013 02:01 AM
Warranty if bought used from an individual? Anthony Issues | Warranty | Recalls / TSB 2 09-02-2013 02:11 AM
Individual 3M Clear Bra parts DoomsdayJesus Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 08-09-2013 11:34 AM
The individual age poll tranzformer Scion FR-S / Toyota 86 GT86 General Forum 41 01-05-2012 03:01 AM
The individual income/salary poll xantonin Scion FR-S / Toyota 86 GT86 General Forum 79 05-06-2011 10:49 PM
