Old 02-11-2014, 09:21 PM   #1
mmontes
Drives: limited brz
Made me-self an Amp Rack
The amp rack is actually held in place by my Cusco strut bar
It ain't going nowhere
added a second battery
battery cut off
2 fans
line out converter
Hifonics Brutus 5000.5
POWERING
13w7 at .75 Ohms behind drivers seat
Infinity Kappa's in door speakers at 2 Ohms
2 JL Audio TR650-cxi's at 4 Ohms in my rear seats
mmontes is offline   Reply With Quote
Old 02-12-2014, 12:21 PM   #2
fz6r
Drives: 13 10 series FRS
I'm interested in seeing this in person
fz6r is offline   Reply With Quote
The Following User Says Thank You to fz6r For This Useful Post:
mmontes (02-13-2014)
Old 02-12-2014, 12:59 PM   #3
Chimera
Drives: FRS
Looks nice.
The Following User Says Thank You to Chimera For This Useful Post:
Old 02-13-2014, 08:36 PM   #4
mmontes
Drives: limited brz
Originally Posted by Chimera View Post
Looks nice.
Thanks a lot guys! Took me a good amount of time and effort to get it the way i wanted it but, I am very pleased with how it functions.
The extra battery REALLY helped with my idle dropping when the bass hits,
now it doesn't flinch when the bass hits
Old 02-17-2014, 03:25 AM   #5
labskaus
labskaus's Avatar
Drives: Toyota GT86
I worry a bit because of the open connectors. Big chance to get a short circuit
labskaus is offline   Reply With Quote
Old 02-20-2014, 07:00 PM   #6
mmontes
Drives: limited brz
I saw your set up.
It is Extremely clean how does it sound?
Any suggestions you have for my amp rack/ system?
Old 02-21-2014, 01:40 AM   #7
labskaus
labskaus's Avatar
Drives: Toyota GT86
How does ist sound ... ? Not as good as I aspected ... only got second place on the German Sound Quality Championship with one point behind the first place. Quiet okay for the first year - but I have to improve.
The car can be filled with music with a good stage - concert feeling without anoying the next 3 blocks with your music. But I always have to put down the back seat for best subwoofer.
Improvement to you install? Protect the power connectors against short circuit. Always use cable sleeves espacially for the connectors on the amp
eg This image has been resized. Click this bar to view the full image. The original image is sized 1600x1009.
It seems that you put the raw cable into it. this will break after a while
The the connector of the power cable on the right 90° down, to protect it from being pushed.
The rest is okay. I have spend together with a professional installer about 200 working hours into the car.
The Following User Says Thank You to labskaus For This Useful Post:
mmontes (02-23-2014)
Old 02-21-2014, 01:46 AM   #8
labskaus
labskaus's Avatar
Drives: Toyota GT86
By the way ... next step will be switching form
headunit -> DSP -> amp
to
phablet/tablet -> DSP by bluetooth -> amp
iPad mini would be great but to not fit right, plus I cannot use torque. Something like a LG G Pad 8.3 would be great, but no chance to sync my iTunes perfect Also the display is not want I expect. Rooting could be an idea, but my last two tries end up in softbricks
Old 02-22-2014, 12:10 AM   #9
soundman98
ProCrastinationConsultant
soundman98's Avatar
can you explain this more? what causes the wire to break? a good install will have limited wire movement, so after everything is connected, it shouldn't be an issue...
Old 02-22-2014, 03:25 AM   #10
labskaus
labskaus's Avatar
Drives: Toyota GT86
It will always be an issue. All forces lay on the pressed wire. Every hard break, every bump, every touch on the cable end up in this point.
These hose stabilize the wires that are pressed together and make the connection into the cable isolation. There are always some string on the wore taht breaks and while drive the ratteling will make it even worth. This process will take some time and if you work on the installtion, everytime the cable will be damage more while fasten the screws. During my installation I think we fix/unfix every cable about 4 times?
So the pros:
look nicer
cable hold longer times
easier for installation
the cons
will cost ... I payed 0.08 to 0.15€ per piece
I use those on every conector I have ... I made some bad experience in the past which costs me a batterie and an amp. 50qmm coppercable directly connected to ground via the amp housing on an batterie plus caps without any fuse ... no fun!
Old 02-23-2014, 04:50 PM   #11
mmontes
Drives: limited brz
Thumbs down
So the pros:
look nicer
I completely agree with you about them looking nicer and making it easier to install in the wire housing on the amp. I'v just honestly never noticed these "hose's" on audio installs before until you mentioned them thank you. I will try to search for them on the internet and get some for myself
Old 02-23-2014, 05:31 PM   #12
labskaus
labskaus's Avatar
Drives: Toyota GT86
With the right tools Easy to do.
Normally i press all in the connector where it will be Install. In best Case, the Hardware is in place and only the wiring has to be done. So angles and placement will be right if you press the wire Hose in the connector
anyone fit a bike rack yet? earthsscum BRZ First-Gen (2012+) — General Topics 108 05-26-2019 11:39 AM
Roof Rack on BRZ Nubbs Cosmetic Modification (Interior/Exterior/Lighting) 6 12-01-2013 05:18 PM
Under deck amp rack Thongpocket Electronics | Audio | NAV | Infotainment 0 10-22-2013 10:05 AM
Bicycle rack. Murseman27 Cosmetic Modification (Interior/Exterior/Lighting) 5 03-19-2013 06:20 AM
Brz limited on the rack at tire rack Nate219BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 07-06-2012 03:01 PM
