Old 02-07-2014, 11:00 AM   #1
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Enkei RPF1 Lug Nuts?
My friend recently had his Enkei RPF1s mounted to his car, and the shop told him our stock lug nuts won't work with the RPF1s. What lug nuts have people used with their RPF1s? I'm worried about purchasing a lighter set of lug nuts since they cross thread easily, and I'm constantly changing my wheels/tires. Thanks!
PoorMansRacing is offline   Reply With Quote
Old 02-07-2014, 11:12 AM   #2
vroom4
Ive been using the standard $50 set of gorilla lugs on my mazdaspeed3 for 2 years...wheel changes 2-3 times a month with no problems.
Ive heard a lot of people on here using the muteki.
vroom4 is offline   Reply With Quote
Old 02-07-2014, 11:22 AM   #3
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
I'm using stock lugs, it should be fine. Unless he "needs" to change them out :p
Plxdjake89 is offline   Reply With Quote
Old 02-07-2014, 11:51 AM   #4
mad_sb
Drives: 2013 Asphalt FR-S
That is not true man, I'm fairly sure the stock lugs do not seat correctly with "tuner" wheels. You need tuner style lugs with tuner wheels due to the difference in seat design.
http://www.tirerack.com/wheels/tech/...jsp?techid=102
EDIT: as others in the thread have pointed out the factory lugs are the correct taper and seat type and could be used. Guess i was remembering my mitsu days with the flat face lugs.... I think i had to run tuner lugs on the fr-s with the SSR's i got because the stock lugs and socket would not fit.
Old 02-07-2014, 11:58 AM   #5
vroom4
Subaru factory lugs are CONICAL seat. 60 degree taper like aftermarket. Much smaller seat than an aftermarket lug though.
Old 02-07-2014, 12:00 PM   #6
vividracing
vividracing's Avatar
You can go for a set of standard Muteki's or upgrade to a sr35's or sr48's.
vividracing is offline   Reply With Quote
Old 02-07-2014, 12:13 PM   #7
Plxdjake89
Plxdjake89's Avatar
Ok
Old 02-07-2014, 12:48 PM   #8
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
The stock lugs are kinda short too if the wheels have deeper holes
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 02-07-2014, 12:51 PM   #9
vroom4
yes, I wasnt saying they work for every aftermarket wheel, i was just disputing the incorrect blanket information posted.
Old 02-07-2014, 01:24 PM   #10
wparsons
wparsons's Avatar
Both the factory wheels and RPF1's are conical (tapered) seat, the stock lugs work 100% fine on RPF1's. Source, other threads and personal experience. The factory locking lug key is a tight squeeze in the RPF1's, but it works fine.
flickr
Old 02-07-2014, 02:17 PM   #11
FR-S Matt
I went with Ray's. Tough and durable and look great.
Old 02-07-2014, 02:19 PM   #12
Stock BRZ/FR-S lugs will work. Don't attempt to use stock lugs from other cars though.
Old 02-07-2014, 02:56 PM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This guy knows whats up. I bought my set from @CSG David.
Old 02-07-2014, 05:56 PM   #14
CSG David
CSG David's Avatar
We got one of the toughest and most durable lug nuts than probably most lug nuts on the market.
/excess shameless plug
FR-S' with Enkei NT03+M and Enkei RPF1 in SBC Finish! 2 3 Touge Factory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 11-12-2013 01:35 PM
Enkei RPF1 17x7+42 anyone? Gearhd79 Tracking / Autocross / HPDE / Drifting 87 07-30-2013 12:08 AM
Enkei RPF1 18x9.5 +38 maj75 Wheels and Tires 16 05-22-2013 09:28 AM
17x9 Enkei RPF1's now available! UncleFester Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 02-09-2013 05:34 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
