Old 02-05-2014, 07:04 PM   #1
Scion10SeriesFR-S
Scion10SeriesFR-S's Avatar
Drives: Scion 10 Series FR-S 1,244 of 2,500
Send a message via AIM to Scion10SeriesFR-S Send a message via MSN to Scion10SeriesFR-S Send a message via Yahoo to Scion10SeriesFR-S
215/45R17 Winter Tire Questions
I definitely need to get a set for the snowy Pennsylvania roads. Can you only purchase rear tires, or it best to purchase four winter tires? What is the negative if only 2 are purchased for the rear? Can you use the factory rims and just alternate between the winter and summer tires? Any suggestions would be greatly appreciated. Sorry for asking if already answered in other areas of this category. Thanks in advance for answering my questions.
Scion10SeriesFR-S is offline   Reply With Quote
Old 02-05-2014, 07:18 PM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Buy four. Check out why on TR's website. It's an easy decision.
Old 02-05-2014, 07:53 PM   #3
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
If you lose traction in the front, which you will...will the only rear two save you? Understeer in the snow is just as bad as oversteer...though i'd take oversteer any day.
Don't be cheap, if you can afford to buy a new car then you afford to buy a full set of winter tires.
$2000 wheels? Different story...
ice, snow, tires, winter tires
Tire Rotation Interval Questions HunterGreene Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-03-2016 09:40 PM
Couple tire/wheel questions Jayde Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-19-2012 02:18 PM
What Winter Tire for NY Weather? ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 84 10-29-2012 07:02 PM
Winter tire Dub666 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:32 AM
Need some help picking a winter tire... jm1681 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 08-29-2012 01:14 PM
