in orbe terrum non visi
Drives: violent
turbo with hood
mods move if needed
I know there is already a thread on this but it seemed to not go anywhere. Who has ran a front mount turbo with the factory hood then changed to a vented? An oil cooler and an upgraded radiator is MORE $ than a vented hood and i dont care how good your cooler is its hard to get air to move into a sealed box. On a budget i honestly think vented with stock cooling system will be more beneficial. DISCUSS! |
King of Kiwi Palace
Drives: Faster than you
majorly depends if you have a water cooled turbo
#3 | |
Junior
Drives: a car
What has been said, water cooled turbos are the best option. not sure where youve been looking at vented hoods but I'd go with seibon and it's not exactly cheaper than a koyo rad and a oil cooler kit
Drives: White FR-S
One thing people may not have noticed is @CARNZ pieced together the coolant-cooled oil cooler from the new Forester XT. It's substantially cheaper than the air-cooled kits.
http://www.ft86club.com/forums/showthread.php?t=50427 I'm not sure how it compares to the aftermarket kits though. |
Junior
Drives: a car
Drives: White FR-S
#7 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
Drives: White FR-S
I suppose, but it would have to be the sandwich plate that gets damaged. It's an OEM solution so I trust that it's pretty good.
Drives: 2014 FR-S
The XT cooler will be just as reliable if not more so than aftermarket solutions. it's just a sandwich plate and a bunch of hard lines. subaru have been using them for years.
#10 |
Drives: violent
his system(forester oem) runs coolant through a sandwich plate around the oil filter unlike other systems that run the oil through a seperate tank in the radiator.
The forester system is NOT as effective on a water cooled turbo since it is essentially doing the same thing. Running coolant through the turbo while oil is running through it. But if i was running an oil only turbo i would use it. |
| Carbon hood and hood dampers?? | ft86me | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 10-19-2013 11:57 AM |
| Hood pins with vis hood or is it okay | Frs32907 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-31-2013 08:02 PM |
| Looking for vis aem hood or seibon fa hood ready to ship | Frs32907 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-29-2013 11:25 PM |
| Looking for Hood Dampers meant for CF hood. | Vicious LED | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-31-2012 02:47 AM |
