Old 07-14-2013, 08:56 PM   #1
tech86
Drives: 86 GTS
Lug Lock nuts - confused with type etc
Bought a set of rays second hand for my 86 but having never changed wheels before, slightly confused with the lug nut situation. Have also seen reference to hubcentric rings, I didn't get any with the wheels but do I need them?
Went down to a local shop who told me I needed some expensive brand name lugs to suit the wheels, don't recall the brand but I almost fell over at the price and walked out.
My searching here leads me to believe the the OEM lugs already have the correct tapered base to suit the aftermarket wheels so can I just use them until I find a lock nut set?
I've found a couple ideas from searching the forums, price in either case is fine.
McGard Spline Drive Black Lug Nut Installation Kit With Locks 12 x 1.25 (lugshack)
Volk Racing Rays 17 Hex 12X1.25 Lug Nuts (rallysportdirect)
I don't want any pretty colours or need light weight lugs, just normal ones that will hold my wheels on tight regardless of how many times I remove them!
Appologies if this is listed in a FAQ somewhere, I searched a lot of threads, info overload
tech86 is offline   Reply With Quote
Old 07-14-2013, 11:18 PM   #2
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I got the gorilla lugs, they were like 30 something from amazon
dori. is offline   Reply With Quote
Old 07-14-2013, 11:52 PM   #3
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
My stuck lugs worked on my CCW classics.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 07-14-2013, 11:58 PM   #4
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
I used one stock lug on my rpf1s and it scratched the inside of the wheel where the lug goes.
Lee358 is offline   Reply With Quote
Old 07-15-2013, 12:43 AM   #5
tech86
Drives: 86 GTS
Yeah I tried one and looks like the same thing. The taper on the OEM lug nut isn't deep enough so looks like the hex part is touching the taper on wheel hole (if that makes sense?)
Tried a few local wheel shops and all I could find was bling aluminum stuff for crazy money. Do I take a gamble with lugshack and hope they turn up quick and the right thing?
Old 07-15-2013, 01:03 AM   #6
Willsonk
Drives: Scion FR-S Asphalt AT & XB
I have the McGard ....... they work great. And yes you need hubcentric rings. Got them from Costco for $3. 89lbs ft pounds is the torque for the lugs.
http://www.mcgard.com/automotive-2/i...gory_pathway=0
Willsonk is offline   Reply With Quote
Muteki and Kics lug nuts in stock at B2autodesigns b2autodesigns Wheels and Tires 815 09-10-2017 08:33 AM
**BEST Lug Nuts with Lock*** ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 05-25-2014 04:22 PM
RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? 20valvewynn83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-07-2013 04:33 PM
Work Racing RS Type Lug Nuts 12 x 1.25 JPxM0Dz Canada Classifieds 2 02-18-2013 09:04 PM
J2 Motorsports- LUG NUTS GROUP BUY- ASSORTED TYPE J2 Motorsports Groupbuys 6 11-27-2012 08:16 AM
