Old 01-30-2014, 12:03 AM   #1
brillo
Drives: 2013 Firestorm FR-S
Material to repair plastic airbox
One of my oil cooler lines has been rubbing the stock airbox. While there is no hole, I'd like to fix/reinforce the spot. What filler, glue, expoy can I use that can handle the high underhood temps?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 01-30-2014, 12:29 AM   #2
Ghost 86
Drives: 2013 Whiteout FR-S
They have plastic weld at the auto store
Ghost 86 is offline   Reply With Quote
Old 01-30-2014, 12:34 AM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You might want to reroute your cooling lines too. (don't flame me - just stating the obvious)
Old 01-31-2014, 02:04 PM   #4
brillo
I am making changes to reroute the lines going forward
Old 01-31-2014, 05:22 PM   #5
mad_sb
Drives: 2013 Asphalt FR-S
check out JB Plastic weld
Old 08-28-2014, 02:09 AM   #6
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
I have the same issue. Found the stock air box with small burn marks. I wondering how hard is it to remove the air filter now that the oil lines are on the way.
vignesh is offline   Reply With Quote
Old 08-28-2014, 05:15 AM   #7
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
+1
Old 08-28-2014, 09:27 AM   #8
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
To be honest, it would probably be easier/cheaper to get on your local forum/facebook group and get a hold of someone's take-off airbox. I just had to do the same thing. Nearly all our locals are running some sort of after-market intake, so finding a stock airbox was pretty easy.
FrX is offline   Reply With Quote
Old 08-28-2014, 09:47 AM   #9
CBR600RR
Drives: Raven Black
Put tin tape over the spot after. the oil cooler line shouldn't rub through that .
Alcantara material? ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 13 06-03-2015 05:24 PM
DI seal improved material radroach Engine, Exhaust, Transmission 21 01-16-2014 01:42 AM
Brake pad material solort Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-20-2013 01:43 AM
How to repair black diffuser plastic? ft86Fan Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 12-22-2012 10:35 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
