Old 01-26-2014, 06:55 PM   #1
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Greddy Intake/Cusco Oil Catch Can Help
So I have the Cusco oil catch can, which when I initially installed it, the exit tube just dangled down on the passenger side and exited to atmosphere. It came with this small metal plug for the intake for the excess air reserculation tube from the head.
In installing the Greddy Intake, the hole for this plug had to be widened slightly since it's hard plastic and not soft, like on the stock intake.
As a result of not having the exit tube on the oil catch can head back into the intake, when running hard (i.e. auto-x or track days) I'd throw a check engine light for running lean on the right bank.
So I tried putting the oil catch can exit tube back into the intake and took out the plug. But because the hard plastic had been reamed out slightly, the factory elbow would not fit cleanly. As a result I put the factory intake back in. No more check engine lights, but I really want to put the Greddy intake back in.
Any suggestions as to places to get rubber seals that'll help create a good seal?
Thnx in advance for any help
omegared19 is offline   Reply With Quote
Old 03-03-2014, 09:18 AM   #2
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
Catch can should be plugged on the PSV on the left of the motor, not on the inlet tube, for NA configuration...
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 03-03-2014, 11:15 AM   #3
banane63
banane63's Avatar
More info here :
http://www.ft86club.com/forums/showp...3&postcount=75
Used Cusco Oil Catch Can FRS_Jack Engine, Exhaust, Bolt-Ons 1 11-19-2013 02:18 PM
F/S Cusco oil catch can wbradley Canada Classifieds 3 07-18-2013 01:16 PM
FS: Cusco Oil Catch Can JPxM0Dz Canada Classifieds 8 04-21-2013 11:46 AM
CUSCO OIL CATCH CAN DIY Margovincent_22x DIY (Do-It-Yourself) Guides 4 01-19-2013 08:18 PM
