Old 01-25-2014, 11:36 AM   #1
FLL_1979
Drives: 2014 Scion FR-S
Pioneer AVHX8500BHS - Wiring harness
I am trying to install a Pioneer AVHX8500BHS on my FR-S, but I am having issues with the wiring.
I have purchased the Metra 70-1761 and I'm looking for the instructions that explain how to connect the different cables.
I was trying to follow this chart (http://www.installdr.com/harnesses/toyota-wiring.asp), but the colors of the cables are different.
Not sure if I'm looking at the wrong instructions or if I'm going crazy... Any suggestions?
FLL_1979 is offline   Reply With Quote
Old 01-25-2014, 11:51 AM   #2
White64Goat
Having not pulled a factory radio out of these cars, there is sometimes a wiring diagram glued to the factory radio. If not, I'd look in the electronics forums. Maybe Crutchfield sells a harness?
Old 01-25-2014, 12:01 PM   #3
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
If you look hard at the wires, they have their functions printed on the wires.
^GT5 Replay Photo Mode^
Old 01-25-2014, 12:58 PM   #4
FLL_1979
The Metra harness does have the functions printed on the wires. My problem is the harness that came with the stereo. It looks pretty much like this: http://i00.i.aliimg.com/photo/v0/112...e_Harness_.jpg
A couple of wires do have a tag with the function on it, but most of them don't...
Old 01-25-2014, 01:02 PM   #5
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Read the manual that came with your head unit. I've done quite a few installs, and usually the colors - even if they don't match perfectly - are pretty close, and if you are in doubt, you can just check the manual.
Prog is offline   Reply With Quote
Old 01-25-2014, 01:35 PM   #6
FLL_1979
Found the instructions in the manual! Thank you! Not sure why they put them on page 24 after basically explaining how the whole head unit works. Shouldn't they be on page 1?!
Old 01-25-2014, 01:55 PM   #7
Prog
Prog's Avatar
JVC puts them on the back of the box for at least of couple of their units that I've installed. Pretty good practice if you ask me. :P
Old 01-26-2014, 08:36 AM   #8
SirBrass
SirBrass's Avatar
Usually, wiring & connection directions are printed in a separate fold-out sheet from the HU manual, and it gives the wiring harness description, in addition to other important information.
Old 01-26-2014, 11:09 AM   #9
FLL_1979
I figured out how to connect most of the wires. Now I'm left with a couple of questions:
1) The light green parking wire from the Pioneer unit comes with a red lead that says "0.5 AMP 0.85". I would like to connect that wire to the green wire from the brake bypass (http://ecx.images-amazon.com/images/...LL._SY300_.jpg). Should I remove the red lead and connect the wires? Or should I keep the red lead and connect the green wire from the bypass to the lead?
2) I have connected the blue wire from the Scosche LSAAB power antenna adapter (http://www.sonicelectronix.com/pictu...&picture_id=-1) to the blue antenna wire from the Metra harness.
I figured that either the black or white plug connects to the harness coming from the car... but what to do with the remaining plug?
wiring harness so26 Electronics | Audio | NAV | Infotainment 5 10-30-2013 04:19 AM
Wiring Harness Question Sigh-on-Rice Electronics | Audio | NAV | Infotainment 0 08-10-2013 11:46 PM
FS: Full Engine Wiring Harness DieselxIndustry Engine, Exhaust, Bolt-Ons 3 06-25-2013 03:14 PM
3rd harness wiring? kndonlee Electronics | Audio | NAV | Infotainment 3 07-01-2012 08:49 PM
Wiring harness sastexan Electronics | Audio | NAV | Infotainment 0 06-17-2012 12:41 AM
