Old 01-22-2014, 10:41 PM   #1
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Hard lurch, don't know what it was
My car is basically all stock. Was driving in traffic today. Stop and go kind of stuff. One time I start going from a stop in first. Right about when I let out the clutch, can't remember exactly when, there was a sudden lurch. First I thought I had hit a rock or some obstacle under my car which caused resistance. But there was nothing there.
It also felt like a sudden fuel cut off. But then right after everything got back to normal. It's not like I let the clutch out super fast or anything, just a normal start from zero.
IDK if it was just an "occasional thing" these engines do, or if it's a sign of some underlying issue that could get worse?
Any ideas or similar experiences?
dave77 is offline   Reply With Quote
Old 01-22-2014, 11:49 PM   #2
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Did you perhaps spin a wheel with TC on? Was there a nasty lump in the road that might have triggered the anti-hop function?
Ganthrithor is offline   Reply With Quote
Old 01-23-2014, 12:27 AM   #3
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
well I guess that's possible. I don't exactly remember any bump or hole in the road. it seemed smooth to me. The lurch/cutoff was so sudden and harsh, I was shocked. But ive never heard of the anti hop function...
Old 01-23-2014, 12:29 AM   #4
EpicNameBro
Drives: Slow...
I had a similar experience it's happened recently probably like 3 times randomly. I didn't think anything of at first but the fact that it happened more than twice has me cautious... no cel and none of the driver assist were off either...
EpicNameBro is offline   Reply With Quote
Old 01-23-2014, 12:34 AM   #5
humfrz
I've had something like that happen when the car is cold and I start off from a stop and I'm turning right.
I reckon it's just a quirk......
TONYpepperon1 (01-30-2014)
Old 01-23-2014, 12:45 AM   #6
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
Mine does it once in a while as well. Feels kinda like how the car jumps off the throttle really quickly when you crest a hill in cruise control but much harder.
Evil Jesus is offline   Reply With Quote
Old 01-23-2014, 12:51 AM   #7
EpicNameBro
Drives: Slow...
Yeah at first i didn't think much of it but 2 times in particular its been cold start but for the most part it has been while the car was warmed up... curious what the issue may be...
Old 01-23-2014, 02:06 AM   #8
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
interesting that others have had the same experience. kinda glad that in not the only one. mine was with the car warmed up, no driver aids turned off. I have about 5200 miles.
Old 01-29-2014, 12:05 PM   #9
moojpg2
Drives:
My brz does it too sometimes. I think its just a quirk of the tc system when starting off if there are bumps or sand the tires want to chirp easily
moojpg2 is offline   Reply With Quote
The Following User Says Thank You to moojpg2 For This Useful Post:
dave77 (01-30-2014)
Old 01-29-2014, 01:24 PM   #10
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
This used to happen to me before I figured out that my DW Fuel Pump was installed incorrectly. Whole thread about it Could also be TC acting up like they said but if it's the pump, it's completely random and can force a fuel cut in any driving situation.
Zach3794 is offline   Reply With Quote
The Following User Says Thank You to Zach3794 For This Useful Post:
dave77 (01-30-2014)
Old 01-29-2014, 01:34 PM   #11
stugray
Drives: 2013 GBS BRZ Limited
My two thoughts were:
1 - Were you runnning low on fuel? turning with nearly empty fuel can cause air to enter the FI system.
2 - A patch of ice (then I noticed "Miami").
My experince living in Fl from CO: If it gets below 55deg in Fl. the locals don artic parkas while the CO natives walk around in shorts...
The Following 2 Users Say Thank You to stugray For This Useful Post:
dave77 (01-30-2014), wparsons (01-29-2014)
Old 01-29-2014, 05:36 PM   #12
EpicNameBro
Drives: Slow...
Neither of those have been the case for me as my car rarely sits below 3/4s empty... driving conditions are always good when it happens...
Old 01-30-2014, 03:53 AM   #13
NickFRS
Drives: 2013 Asphalt FRS
noticed you use this ram air intake. Maybe you should get a tune.
http://www.ft86club.com/forums/showthread.php?t=55447
Also noticed you hit something.
Get your front end checked out.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 01-30-2014, 12:03 PM   #14
350matt
Drives: toyota mr2/ Toyota GT86
this soudns like the TC / VCS to me as the standard setting is very agressive - feel like someone has turned the engien off briefly
switch in to 'sport' and it should stop doing it
350matt is offline   Reply With Quote
Hard start ?? Rayme Issues | Warranty | Recalls / TSB 44 03-28-2015 08:51 AM
How hard a hit before damage is likely? Ben_G Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-05-2014 08:16 PM
Top? t-top, removable hard-top incubus1995 Cosmetic Modification (Interior/Exterior/Lighting) 9 11-30-2013 10:23 AM
How hard is it really? Kimsey47 Issues | Warranty | Recalls / TSB 13 08-16-2013 11:01 PM
Was I being hard on my car? Fr-s13 Scion FR-S / Toyota 86 GT86 General Forum 49 07-04-2013 09:54 PM
