Old 01-19-2014, 11:25 PM   #1
brillo
Drives: 2013 Firestorm FR-S
bizarre fuel economy reading?
So I wanted to test my highway mileage on a relatively short trip to the north part of town after getting my new tires (michelin PSS). The route was all toll road so I figured it was a good steady state 70mph test. My car has perrin tune stage 1 tune, perrin filter and a oil cooler. Otherwise its stock.
So after 33 miles round trip my mpg calc (to my major surprise) was 23 mpg (pump showed 1.44 gal). I was like WTF? I made the mistake of not filling up at the same place both times (dumb) so I have to think the pump had an issue. The weather was cool but not cold, no wind, and my car had recently gotten ~25 mpg in my last tank of driving (mixed city/hwy).
Is 33 miles to short a distance to test? Gas pump issues? What else could I be missing?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 01-19-2014, 11:30 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
No...? I don't see what the problem is...?
Old 01-19-2014, 11:30 PM   #3
Luis_GT
I get 27MPG if I do 200 miles of highway...
Old 01-19-2014, 11:31 PM   #4
brillo
The problem is my hwy mileage was 23 mpg which is way to low based on historical observation and the cars EPA ratings.
Old 01-19-2014, 11:31 PM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
You are trying to calculate your Miles per Gallon.
You drove 33 miles, and returned 23 Miles Per Gallon.
You don't even drive enough to average the mileage of 2 gallons of fuel.
Don't believe the gauge - It's not as accurate as manually calculating your fuel usage.
Rayme is offline   Reply With Quote
Old 01-19-2014, 11:33 PM   #6
N1rve
N1rve's Avatar
Well your car is running PSS, stickier tires, the stock tires were Prius tires with low rolling resistance.... soo that would account for it.
Old 01-19-2014, 11:33 PM   #7
brillo
I was manually calculating it. I went 33 miles per the odometer and the pump said I burned 1.44 gal of fuel
Old 01-19-2014, 11:36 PM   #8
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
It's very difficult to consistently fill up with modern self-stopping pumps, even at the same pump, especially if they're set up for vapor recovery.
And even if you were to take an average over several tank fulls, there would be so many variables involved with each tank-full that you still wouldn't know for sure what the true "highway" mileage was.
993Fan is offline   Reply With Quote
The Following User Says Thank You to 993Fan For This Useful Post:
Rio (01-19-2014)
Old 01-19-2014, 11:41 PM   #9
brillo
Tire rack shows the PSS makes a - 1% difference vs their most efficient tire. My cars computer mpg was 32.5mpg when I stopped to fill up.
Old 01-19-2014, 11:45 PM   #10
N1rve
N1rve's Avatar
Have you checked your tire pressure lately?
Old 01-19-2014, 11:49 PM   #11
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
run a tank...33 miles is not nearly enough....
ntron1 is offline   Reply With Quote
Old 01-19-2014, 11:56 PM   #12
brillo
Yep pressures are 34/35 psi
Old 01-20-2014, 12:19 AM   #13
Cyau
Cyau's Avatar
Drives: UltraMarine FRS MT
No one has mention the tune yet?
Most tuning are gear toward performance, not efficiency.
Cyau is offline   Reply With Quote
Old 01-20-2014, 12:50 AM   #14
brillo
I wouldn't think an NA tune would affect closed loop cruising. I've gotten 30ish before on long hwy trips with the stock tires.
Going to guess 33 miles is to short a distance to test.
Why isn't the fuel economy better? White Shadow Scion FR-S / Toyota 86 GT86 General Forum 495 10-28-2019 09:21 AM
Fuel gauge not reading properly FR-S Hot Lava Issues | Warranty | Recalls / TSB 27 10-29-2014 11:33 AM
Fuel economy ozne99 BRZ First-Gen (2012+) — General Topics 48 12-11-2012 01:55 PM
Optimistic fuel economy? nubbster927 BRZ First-Gen (2012+) — General Topics 15 07-05-2012 09:50 PM
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 04:50 PM
