Old 01-16-2014, 01:21 PM   #1
Sprocket
Drives: Hunk a Junk
Which Kit to Choose?
Hey guys
I've been throwing around the idea of a turbo kit for quite some time now. In the beginning, I'm only looking to make no more than 300hp. However, over time, that number will definitely rise more towards 400 as the engine internals are built. The problem I have is that I will mostly use the BRZ as a DD in most weather. From what I've read, people are saying that the smaller turbos put a bit more stress on the parts from the torque surge, versus a larger turbo. My understanding, from reading some posts here, is that if I used a turbo like the T3/4 it would put less stress on the parts versus a gt35 due to less of that torque surge. Given that I'm looking to make power reliability with a smooth powerband and not break too many parts, what kit(s) would you guys recommend?
Sprocket is offline   Reply With Quote
Old 01-16-2014, 02:28 PM   #2
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
We offer and have installed many different types of forced induction here. Give me a call at the shop and I can go through all your choices personally with benefits and downfalls to each kit.
Mike
PrimeMotoring is offline   Reply With Quote
The Following User Says Thank You to PrimeMotoring For This Useful Post:
slates74 (01-21-2014)
Old 01-16-2014, 03:27 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
These statements are contradictory. The T3/T4 is a small turbo compared to a GT35. The torque that you put down is what will put stress on the parts. Changing the size of the turbocharger only changes when that higher torque starts and how much of it there is. Just because a larger turbo takes longer to reach peak torque doesn't mean it puts less stress because eventually it will be putting down more peak torque than a smaller turbocharger.
The Following User Says Thank You to King Tut For This Useful Post:
Ny Brz (01-17-2014)
Old 01-16-2014, 03:29 PM   #4
protpibe
protpibe's Avatar
I don't really know what torque surge is and how it would wreck a motor, but I haven't heard of many 300hp motors dying. Your biggest threat to the long life of your motor will be the quality of tuning on the fuel maps.
Old 01-16-2014, 07:31 PM   #5
Sprocket
Drives: Hunk a Junk
Mike
I will surely do that when I'm ready for a kit! East Rutherford is close to me also. Only about 20 minutes away
The Following User Says Thank You to Sprocket For This Useful Post:
PrimeMotoring (01-17-2014)
Old 01-16-2014, 07:35 PM   #6
Sprocket
Drives: Hunk a Junk
Not so much the motor, but more items such as the CV joints. I've seen some threads where the CV joints grenade themselves with (if i remember correctly) relatively low HP numbers. I want to avoid that as much as possible
Old 01-16-2014, 08:44 PM   #7
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
@PrimeMotoring did my turbo install and JR did my tune(Amazing). There are so many kits to choose from. I daily drive my car about 60-70 miles a day and am very happy with my setup 266 on low boost and 329 on high boost on the mustang dyno. Call up Mike from Prime he can lead you in the right direction.
Ny Brz is offline   Reply With Quote
The Following User Says Thank You to Ny Brz For This Useful Post:
Old 01-16-2014, 11:22 PM   #8
Sprocket
Drives: Hunk a Junk
I was just researching about Prime Motoring and checking out their facebook page. Looks like they do some top notch work. I also saw some pictures of your exact car, that pink logo is unmistakable. What kit did you get? And are you running stock engine internals?
Old 01-16-2014, 11:34 PM   #9
Ny Brz
Hella Flush
Ny Brz's Avatar
I have the FA20club UEL kit and love it, it's seems like they are taking a big hit nowadays with issues of their welding and time frame. I am on stock internals and I don't really have plans of going over 400whp, most important is tuning. What are your expectations of for your car, type of header setup, max hp wanted?
Old 01-16-2014, 11:48 PM   #10
Sprocket
Drives: Hunk a Junk
My initial plan is to just have around 270-300hp. I suppose i could try to make that work N/A, but I'm still definitely leaning towards the turbo route. I want good power with reliability, because its a car I use basically every day, thats why I don't want to push the limit too far on the stock internals. After keeping it around 300hp for a while, I'll probably put some forged internals into it and move on up to the 350-400hp range. I don't really see myself ever going over that amount of power. I'm basically looking for a turbo kit to make some decent, reliable power. I realize that tuning is very important to meet those goals. It's just that I've heard of CV joints breaking and the speculation that it may be linked to how different turbos spool up due to their turbine size and the shape of the powerband. I may be completely wrong though. I'm just looking for more power, reliably.
Also, with your kit, how much of a turbo lag do you experience? As is the nature of turbos, there is some delay versus a supercharger. I realize that tuning can limit the lag, and I have no doubt that Prime tuned your kit well. With that being said, how much lag is there with a well tuned kit like yours? I understand its a bit of a vague and general question lol
Old 01-17-2014, 12:37 AM   #11
Ny Brz
Hella Flush
Ny Brz's Avatar
We'll if your seeking reliability you may want to consider a supercharger, friend of mine made 260whp on stock fuels sytem an tuned. I drive everyday and keep it on low boost, my boost starts in at about 3500rpms hits full boost at about 4200rpms.
Old 01-17-2014, 12:49 AM   #12
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Jackson Racing or Kraftwerks make good power and have a fairly linear powerband that shouldn't put a ton of extra stress on your driveline.
JoeBoxer is offline   Reply With Quote
Old 01-17-2014, 10:09 AM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Where are you hearing this? There are guys that AutoX that are breaking CV joints who are all motor and plenty of people running various turbos that have had no CV issues.
CSG Mike (01-17-2014)
Old 01-17-2014, 06:27 PM   #14
Sprocket
Drives: Hunk a Junk
This link right here
http://www.ft86club.com/forums/showthread.php?p=897624
Guy says he's running about 285 whp
Why did you choose the BRZ over the FRS? chenshuo BRZ First-Gen (2012+) — General Topics 371 08-08-2014 02:43 PM
Why Did You Choose the FR-S over the BRZ dirtbike250x Scion FR-S / Toyota 86 GT86 General Forum 1 05-13-2013 06:42 PM
Help me choose a car for my mom. Mandy Other Vehicles & General Automotive Discussions 16 04-28-2013 12:50 PM
Help me [maybe?] choose a new car: tree fingers Other Vehicles & General Automotive Discussions 24 04-16-2013 05:27 PM
Why did you choose the BRZ? pinoyplaya BRZ First-Gen (2012+) — General Topics 43 10-10-2012 03:34 PM
