Old 01-16-2014, 12:50 PM   #1
tomato86
tomato86's Avatar
Drives: '13 FR-S | '08 Evo [Sold]
FA20 oil cap thread size?
Can we buy oil caps that are made for Subie EJ engines? Are they the same thread pitch? Asking since it would open up a ton of choices.
'13 FR-S |
'08 EVO [SOLD] | ARC Intercooler | Tomei Expreme Ti Exhaust | Blitz Intake Pipe | HKS Intercooler Piping | HKS Spark Plugs | Blitz SUS Power Filter | ECUTek | Varis x Runduce Aero | Enkei RPF1
tomato86 is offline   Reply With Quote
Old 01-24-2014, 01:15 PM   #2
tomato86
tomato86's Avatar
Anyone? Not sure if anyone really knows whether Subaru kept the thread pitch the same.
'13 FR-S |
Old 01-24-2014, 06:15 PM   #3
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
The short answer to your question is yes. Subaru kept the same thread size and pitch as the EJ motors.
The longer answer to your question is that I would advise you be aware of the thread depth. What I found in the design of our FT86 oil cap is that the thread on the cap needed to be a bit shallower than on the EJ oil fill tubes. The bottom of the threads on our 'Subaru' oil caps were actually bottoming out on the aluminum timing cover instead of allowing the o-ring to make the seal. They actually did seal and worked fine, but it's not an ideal solution. Now, it could be that our 'Subaru' oil caps are just a bit deeper than stock EJ oil caps, but it's not an issue on the EJ motors, so we've never bothered to check.
Hope that helps!
Matt Beenen
Engineering
GrimmSpeed is offline   Reply With Quote
The Following User Says Thank You to GrimmSpeed For This Useful Post:
enjoi23 (01-24-2014)
Old 01-28-2014, 12:04 PM   #4
tomato86
tomato86's Avatar
Hope that helps!
Matt Beenen
Engineering
Makes total sense, thanks. Well, I don't want to waste my money so I might just stick with what's made for the FA20...
'13 FR-S |
Official OpenFlash Tablet FA20 Tuning Tech Discussion Thread Rombinhood@OpenFlash Software Tuning 2594 08-01-2017 01:03 AM
Thread size for BRZ / FRS Antenna Uniquedetail Cosmetic Modification (Interior/Exterior/Lighting) 5 10-10-2016 03:27 PM
What is our lug nut thread size? LeeMaster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-21-2013 06:30 PM
Hub thread size and stock lug nuts onedollarodent Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-07-2012 08:40 PM
