Old 01-15-2014, 01:00 AM   #1
stugray
Drives: 2013 GBS BRZ Limited
Please post a logcfg file that works for OP2.0
I cannot get my OP2.0 to log anything in standalone mode.
Would someone please post a logcfg.txt file that they have personally witnessed working on a BRZ.
I would even appreciate seeing the logcfg.out file that it generates.
My ROM is ZA1J700C if that helps any.
I dont even care what data is in it.
I just want to verify that my tactrix is even capable of logging.
Old 01-15-2014, 11:34 PM   #2
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
You can use the logcfg.txt found in the program files directory to test the logging mechanism, it will generate logs. The numbers are all garbage though as they aren't reading the correct addresses for your ROM. You need to flash on ZA1JA01C for the logging to actually work.
AdrianG is offline   Reply With Quote
Old 01-15-2014, 11:41 PM   #3
stugray
I thought I would still be able to log "something" but I would need the definitions if I wanted to know what the data means.
For instance the mem addr for RPM on a ZA1JA00C is 0xFFF8DB80
So if I try to log:
paramname = RPM
paramid = 0xFFF8DB80
isfloat = 1
with my ROM (ZA1J700C) I should still read something from 0xFFF8DB80 but it might not be RPM.
Old 01-15-2014, 11:44 PM   #4
AdrianG
So if I try to log:
paramname = RPM
isfloat = 1
You're right, that's exactly the behavior I was getting. Rpm at idle was a steady -1.37886 on that ROM.
- AdrianG
Old 01-15-2014, 11:44 PM   #5
stugray
I tried the BRZ example logcfg file provided with ECUflash, but I added a trigger for RPM > 0. I got nothing in the logcfg.out file except the init information.
If I am reading garbage maybe the trigger never worked.
Old 01-15-2014, 11:45 PM   #6
stugray
- AdrianG
What did you use as a trigger?
Old 01-15-2014, 11:50 PM   #7
AdrianG
No trigger, it starts logging as soon as it turns on. Not ideal, I know, but AFAIK the defogger hasn't been discovered yet.
Here's what I use, the ones below the comment at the bottom seem to work on ZA1JA01C but not sure if you want them for your test. If you delete/comment out everything at the bottom it'll be an unmodified copy of the file (i think).
Code:
type = obd
protocolid = 6 ; ISO15765
mode23txaddrwidth = 4		; mode23 req format info
mode23txlenwidth = 1		; mode23 req format info
mode23rxaddrwidth = 0		; mode23 req format info
mode23uds = 1			; lets OBD channels know you are using mode23 UDS
sortpids = 1			; sort these PIDs by value to potentially make for fewer requests (=faster)
calcsampinterval = 1000		; timing parameter - leave as is - will make default for release version
; here are some known RAM addresses for ROM ZA1JA00C
; addresses are likely different for other ROMs
; you can comment out ones you don't need, but keep in mind that with
; the block read nature of UDS, reading extra parameters that have
; adjacent addresses comes at very little bandwidth (=sample rate) cost
paramname = load
paramid = 0xFFF8DB6C
isfloat = 1
paramname = cool_temp
paramid = 0xFFF8DB70
isfloat = 1
paramname = STFT
paramid = 0xFFF8DB74
isfloat = 1
paramname = LTFT
paramid = 0xFFF8DB78
isfloat = 1
paramname = MAP
paramid = 0xFFF8DB7C
isfloat = 1
paramname = RPM
isfloat = 1
paramname = speed
paramid = 0xFFF8DB84
isfloat = 1
paramname = advance
paramid = 0xFFF8DB88
isfloat = 1
paramname = IAT
paramid = 0xFFF8DB8C
isfloat = 1
paramname = MAF
paramid = 0xFFF8DB90
isfloat = 1
paramname = fuel_press
paramid = 0xFFF8DBA0
isfloat = 1
paramname = lambda
paramid = 0xFFF8DBA4
isfloat = 1
paramname = O2_volt
paramid = 0xFFF8DBA8
isfloat = 1
paramname = evap
paramid = 0xFFF8DBAC
isfloat = 1
paramname = fuel_level
paramid = 0xFFF8DBB0
isfloat = 1
paramname = amb_press
paramid = 0xFFF8DBB4
isfloat = 1
paramname = O2_curr
paramid = 0xFFF8DBB8
isfloat = 1
paramname = cat_temp
paramid = 0xFFF8DBBC
isfloat = 1
paramname = ECU_volt
paramid = 0xFFF8DBC0
isfloat = 1
paramname = abs_load
paramid = 0xFFF8DBC4
isfloat = 1
; experimental parameters below this line
paramname = accel_pedal_angle
paramid = 0xFFF8922C
isfloat = 1
paramname = IAM
paramid = 0xFFF816F4
isfloat = 1
paramname = throttleplate_angle
paramid = 0xFFF89030
isfloat = 1
paramname = requested_torque
paramid = 0xFFF8B490
isfloat = 1
paramname = knock_advance
paramid = 0xFFF8B0AC
isfloat = 1
paramname = fine_knock_correct
paramid = 0xFFF8B14C
isfloat = 1
paramname = feedback_knock_correction
paramid = 0xFFF8B0B0
isfloat = 1
paramname = engine_load_4byte
paramid = 0xFFF89148
isfloat = 1
paramname = Intake_temp
paramid = 0xFFF87C64
isfloat = 1
paramname = ignition_total_timing
paramid = 0xFFF8ADF8
isfloat = 1
paramname = gear
paramid = 0xFFF895D9
isfloat = 1
isfloat = 1
paramname = gear_calculated
paramid = 0xFFF895DA
isfloat = 1
Old 01-16-2014, 12:02 AM   #8
stugray
excellent! Thanks for the help. It worked.
Coincidentally I set it up to trigger on RPM.
I removed the trigger and it did log finally and the RPM value was zero the entire log so of course it wasnt going to start logging.
Now I will get back to trying to log voltages from the OEM pins on the OBD connector.
Old 01-16-2014, 12:05 AM   #9
AdrianG
Good luck! Now get on with flashing ZA1JA01C before you torch your DI seals.
- AdrianG
File Repository? rupert Site Announcements / Questions / Issues 1 01-08-2014 04:46 PM
Can I map access in ECUtek without a tune file? Cal3000 Software Tuning 11 10-14-2013 08:26 AM
GT 86 Logo in PSD file format avig FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 10-01-2013 02:12 PM
usb mp4 file format wrohdejr Electronics | Audio | NAV | Infotainment 1 04-16-2013 08:19 PM
USB file structure and random play Gunman Electronics | Audio | NAV | Infotainment 1 04-16-2013 04:04 PM
