Old 01-14-2014, 09:33 PM   #1
Skorov
Skorov's Avatar
Drives: 86 GTS White
BRZedit with Auto GTS Issues
Hi all,
Has anyone experienced any issues with BRZedit on auto cars?
At the local tuner's we flashed the ECU on Monday. Went to start the car, and nothing. Doesn't even try to start. The car has a push start button, and even with my foot on the brake is cycles through ACC -> ON -> OFF as if the brake is not pressed. If turn the ignition on and power the starter motor manually, the engine starts just fine.
I should also mention that it has a freshly installed AVO turbo kit.
We've sent all the info we have so far to BRZedit and are waiting for a response, but I thought I'd see if the community has experience anything like this before.
Thanks.
Skorov is offline   Reply With Quote
Old 01-17-2014, 02:38 PM   #2
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Originally Posted by Skorov View Post
Hi all,
Thanks.
Give Driven Performance a call and ask to speak to Anthony 8504768335. They did a local car with brz edit and I believe they ran into something similar but got it worked out.
the new guy is offline   Reply With Quote
Old 01-17-2014, 05:39 PM   #3
Skorov
Skorov's Avatar
Thanks! Do you know his email? international calls are expensive.
Old 01-17-2014, 06:13 PM   #4
the new guy
PM'd it to you.
The Following User Says Thank You to the new guy For This Useful Post:
Skorov (01-17-2014)
Old 01-25-2014, 05:20 AM   #5
Skorov
Skorov's Avatar
Easy fix. The tuner used the wrong base map. We got the right one for the auto and it started right away.
BRZedit E85 How-To mad_sb Engine, Exhaust, Transmission 9 04-24-2020 09:30 PM
BRZEdit (ECUEdit) illmatic Software Tuning 246 06-02-2016 01:15 PM
BRZedit Help Sojhinn Software Tuning 2 10-29-2013 11:40 AM
BRZEdit MAP scaling jamesm Software Tuning 13 10-02-2013 12:43 PM
Auto up and down window Issues? CzRceCar Issues | Warranty | Recalls / TSB 3 08-07-2012 07:44 PM
