Old 01-13-2014, 06:33 PM   #1
swift996
swift996's Avatar
Double Cat Front Pipe? Emissions?
Had a friend with a FRS recently fail an emissions check (cat-less header and open exhaust). I was wondering if you took two OEM front pipes, cut them and welded on both secondary cats if that would be enough to clean up the exhaust? Thoughts? Or does someone make a super restrictive cat-converter?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-13-2014, 06:57 PM   #2
mrk1
Drives: Sterling BRZ Ltd
Well first off how did he fail? Visual? OBD? Tail pipe sniffer?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-13-2014, 07:50 PM   #3
swift996
swift996's Avatar
It sounded like the last, the device that reads whats coming out of the tail pipe.
Old 01-13-2014, 08:00 PM   #4
ciro
Drives: Scion FR-S
just get 2 high flow cats if your concerned....
ciro is offline   Reply With Quote
Old 01-13-2014, 08:00 PM   #5
JS + BRZ
Drives: 2010 MS3
Why did your friend go get it checked with cat-less header and open exhaust?
JS + BRZ is offline   Reply With Quote
Old 01-13-2014, 08:19 PM   #6
Basket Case
Drives: 2013 Raven fr-s
Lol, this. I would just get a high flow cat welded in. I don't see why one wouldn't be enough.
Basket Case is offline   Reply With Quote
The Following User Says Thank You to Basket Case For This Useful Post:
Kuri (01-13-2014)
Old 01-13-2014, 08:36 PM   #7
NickFRS
Drives: 2013 Asphalt FRS
Simple... Put stock back on and roll back through...
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 01-13-2014, 08:41 PM   #8
mrk1
Yeah if your area has a sniffer your best bet is to put stock stuff back on. I've never lived in an area that requires that.
You double cat idea "could" work but its still a shot in the dark.
The Build Thread
Old 01-13-2014, 09:25 PM   #9
FR-S Matt
One cat should get you past the sniffer. They don't have it where I am, yet.
Old 01-13-2014, 09:29 PM   #10
swift996
swift996's Avatar
Just curious because the front pipe is only 4 bolts so it could be a simple swap on/swap off job once every year or how often they test. The intent is to pass the test
(wish to buy) space converters. Turbo UEL please. radium catch can Mr. Want-To-Buy Requests 9 10-20-2014 11:24 PM
Motiv Concepts Over-pipe & Front-pipe Combo's -$439 Shipped - DECEMBER ONLY!!! Rev Works Engine, Exhaust, Bolt-Ons 28 01-13-2014 05:57 PM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
