Old 01-13-2014, 06:01 AM   #1
Victor Draken
Drives: Toyota Gt86
WMI kits
How many of you have tried it on the twins?
Is it reliable or it's tossing a coin for a DD car?
Victor Draken is offline   Reply With Quote
Old 01-13-2014, 09:24 AM   #2
mike the snake
I'll know hopefully this week. Car's getting tuned this week with FB turbo and WMI. Interested to see what numbers it produces.
The Aquamist WMI system is very cool, it has it's own gauge that tells you about any failures and low tank levels.
Old 01-13-2014, 10:05 AM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I believe that @sw20kosh is the only one I know of that has run a WMI setup for awhile, and I believe he removed it due to some issues. I would not run one on a daily driver setup. It just isn't worth the extra horsepower it can produce.
Old 01-13-2014, 01:52 PM   #4
sw20kosh
Drives: 2013 Black FR-S
I've tried it out. In my opinion it isn't worth it. You are adding on complexity with a FI kit. Then you are adding on more complexity with WMI. It's another point of failure. There are ways to mitigate that failure but they require more complexity in the form of failsafe systems.
Additionally, I had to fill the tank (3 gal) up after every 25 min lapping session at the track. I did it for two track days and got sick of having to do that. Takes away from the fun of the day.
That being said, if you get a high quality system that has good failsafes and if you just use it on the street (won't run out of fluid so fast) it can be do-able.
Old 01-13-2014, 06:08 PM   #5
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
Complexity wise if you buy a good quality kit with built in checks then you pretty much set and forget with the exception of topping it up.
this would be no different to running e85 and having to refill the car 2-3 times as well as the added point of failure of an eflex sensor... which is considered to be readily acceptable.
why not get a 5 gallon tank for the WMI kit if you planned to track it?
RAN94A is offline   Reply With Quote
Old 01-13-2014, 06:38 PM   #6
sw20kosh
I don't run E85 flex fuel. Yes that is more complexity. I would argue it is safer/more consistent tuning-wise as you are not relying on a seperate WMI pump, lines, wiring, control module, fail safe, how determine when to spray and how much to spray etc. All you are relying on is the flex sensor and the ecu calibration to be working in harmony.
Filling it up after every 2 sessions isn't all the better than filling it up after every session... To me, at least.
If you go by that logic then why not go with a 10 gal or 20 gal reservoir? You reach a point of diminishing returns where you are making it more "convenient" but reducing cargo space and adding on more weight when you should be reducing weight.
Old 01-13-2014, 06:42 PM   #7
bulldog11267mad
bulldog11267mad's Avatar
Drives: 2013 BRZ Limited manual
i have a aquamist that i will be installing shortly
IAG built stage 3 block, HKS camshafts, built and tuned by national speed. 1050 ID injector, garret GTX3071 93 octane 415whp, E85 524whp monster! Quaife QBE69G sequential transmission!
bulldog11267mad is offline   Reply With Quote
WTB: ht lip kits for the BRZ Vten Exterior Parts (Aero, Lighting, Etc.) 0 05-03-2013 07:49 AM
HID KITS myjobis2pimp NY / NJ / CT / PA 16 03-28-2013 12:40 AM
TSI offers HIDGUY HID kits and LED lighing! $95 kits SHIPPED! We won't be beat! Lisa@TrueStreetIndustries Exterior Parts - Lighting 129 01-18-2013 08:57 PM
Where to buy hid kits? thaiguy8904 Cosmetic Modification (Interior/Exterior/Lighting) 26 09-17-2012 07:09 PM
