Old 01-09-2014, 04:53 PM   #1
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
New full carbon fiber engine cooling plate from APR
A first on the market from APR is their one piece carbon fiber fiber cooling plate that installs in the OEM location over the radiator gap in your engine bay. The plate helps keep air flow around the radiator and not escaping through the gap in the engine bay. The part looks beautiful and installs easily.
Manufacturer description:
The flow of air is not only limited to the outside of a car. To maximize cooling capabilities, a radiator needs a direct flow of air to allow an engine to maintain consistent temperatures on the race track. Because of structural gaps above the radiator, the flow of air could escape making the radiator not as efficient as it could be.
To help improve the flow of air into the radiator, APR Carbon Fiber Radiator Cooling Plates can be utilized to channel the flow of air directly to the radiator. This will improve the efficiency of the radiator while adding a high-tech, race inspired look to your engine bay.
Features:
  • Pre-preg. Carbon Fiber Manufacturing Process
  • The APR Radiator Cooling Plates are constructed by high temperature and pre-preg. carbon fiber production process, making them durable and able to withstand elevated engine bay temperatures.
  • Designed for Easy Installation
  • The APR Radiator Cooling Plates are designed to factory specifications for easy installation and clean fit and finish.
  • Fade Resistant Epoxy Coating
  • To ensure durability, the APR Radiator Cooling Plate uses fade resistant epoxy coating to reduce the effects of high engine bay temperatures.
Writeup / Review
as seen on our blog
The beautiful and functional cooling plate from APR for your 86 / FR-S / BRZ is a great addition to your engine bay that is both affordable and easy to install. We recently got one of the first on the market from APR to install on our shop Scion FR-S – check out the pics below!
Retail price on the cooling plate is $152 – get it through Guerilla Racing with free & fast shipping.
APR Carbon Fiber Cooling Plate – Scion FR-S / Subaru BRZ
Adding this new cooling plate to our FR-S was a total breeze. The kit includes cutouts for all of the stock nuts / bolts and hood latch, making for a truly plug and play installation taking under 20 minutes (or 30 minutes if you’re like me and clean everything under the hood while you’re at it).
The carbon fiber one piece cooling plate is extremely light and has a high quality polish and shine to it, making it one of the first items noticed when opening the hood. It has an OEM fit and finish — very typical for APR products!
The cooling plate is not just an aesthetically pleasing item – it closes the gap in your engine bay to make sure cooler air doesn’t escape from your radiator section. This gap makes the radiator not as effective as it can be while adding a race inspired & high tech look to your engine bay.
Tips for installation (installed on our Scion FR-S, but Subaru BRZ / Toyota 86 is same install) :
  1. Line up APR cooling plate to location at front of engine bay for installation.
  2. Remove nuts from top assembly using 10mm and 12mm socket wrenches and set in secure location. Also remove the hood prop holder plastic piece.
  3. Remove 10mm nuts and two pop-out plastic screws from the weather rubber strip section connected along the front bumper and remove the plate, set aside.
  4. Place APR cooling plate in place for stock nuts to be threaded on to stock location. Install and tighten all bolts / nuts for a secure fitment of the plate to your car – make sure not to over-tighten as you could crack the carbon piece.
  5. Install hood prop holder piece through rectangle provision on the cooling plate and through to original location for a secure fitment.
  6. Re-install weather rubber strip with original nuts / bolts / screws.
GuerillaRacing is offline   Reply With Quote
Old 01-21-2014, 05:46 PM   #2
GuerillaRacing
Drives: Scion FR-S
We just got one for our FR-S, pics and review added above!
Old 01-21-2014, 07:02 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Seems like a viable idea. I'd love to see your results.
Old 01-21-2014, 07:10 PM   #4
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
This does look good, but it looks like it wouldn't fit with the Vortech intake box without some trimming, can you confirm this?
reyruiz191 is offline   Reply With Quote
Old 01-21-2014, 08:09 PM   #5
diss7
Drives: AE86, 2x GT86, TE27
Hate to be 'that guy" (I dont really)...
But is there any testing of data to show this product actually increasing cooling?
diss7 is offline   Reply With Quote
Old 01-21-2014, 08:26 PM   #6
Malt
Drives: 2015 WRX
I second this! I was always under the impression that these were purely cosmetic and labeled as performance parts to draw in the uninformed crowd.
Malt is offline   Reply With Quote
Old 01-22-2014, 12:53 PM   #7
GuerillaRacing
Drives: Scion FR-S
Hey,
There is no data as of yet from APR about that, but they are labeling the part as helping the cooling efficiency and not just a cosmetic part. Sorry we don't have any hard data about it though.
@reyruiz191 Most likely you would need to trim it.
APR Carbon Fiber Cooling Plate - Keep you Bay Cool in Style GuerillaRacing Engine, Exhaust, Bolt-Ons 63 10-13-2014 07:21 PM
Carbon Fiber Full Interior jazztennor Cosmetic Modification (Interior/Exterior/Lighting) 40 04-25-2014 01:36 AM
FS: Password JDM Carbon Fiber Engine Cover and Cooling Plates FRSTRM Engine, Exhaust, Bolt-Ons 9 03-21-2014 01:22 PM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 01:39 AM
Carbon Fiber Brake Cooling Duct JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 7 10-25-2012 12:03 AM
