Old 01-07-2014, 07:59 PM   #1
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Garrett Turbo Oil Restrictor Fitting Question
Hi guys, I'm mounting my turbo right now but I have a question regarding the oil line to the Garrett turbo. The fitting I have seems rather loose, and I'm not sure how tight to screw this oil restrictor fitting on. On top of that, am I supposed to be using thread sealant on this part? Any suggestions? See video:
[ame]http://youtu.be/r0YS5MN2TbI[/ame]
rb6freak is offline   Reply With Quote
Old 01-07-2014, 08:21 PM   #2
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Its a flare type seal, which means no tape/paste on the threads because the angled face is where the seal is made, not in the threads.
Sellout is offline   Reply With Quote
The Following User Says Thank You to Sellout For This Useful Post:
rb6freak (01-07-2014)
Old 01-07-2014, 08:45 PM   #3
Stevemode
Stevemode's Avatar
Drives: "Baby Gurl" of FBM
7/16 inverted flare to -4 male. Both ends seal as Sellout mentioned, however putting a little anti-seize would be recommended. The fitting into the turbo can be tightened fairly snug, and the hose end to fitting should be finger tight +1 "face". Torquing the hose end too tight will crack it.
Stevemode is offline   Reply With Quote
The Following 2 Users Say Thank You to Stevemode For This Useful Post:
Dipstik-sportech (01-07-2014), rb6freak (01-07-2014)
PRE turbo kit (garrett GT3076R) BRZPDX Northwest 90 01-18-2014 10:39 AM
HKS Supercharger with restrictor plate installed and dyno'd Ishii Motors Forced Induction 20 12-06-2013 01:54 PM
Borg Warner Vs Garrett DeBiase Forced Induction 12 12-02-2013 11:17 PM
Garrett GTX2863R turbo, TiAL v-band wastegate Turbowned Engine, Exhaust, Bolt-Ons 10 11-27-2013 02:07 PM
fitting 17x9's with 255s, and fitting brake pads Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-29-2012 11:08 AM
