Old 12-01-2013, 08:57 PM   #1
DeBiase
Drives: 2005 GMC Canyon
Borg Warner Vs Garrett
Hey guys I see a lot of people like the Garrett's and I have heard their name for a long time. I also see a lot of people really love the Borg's. can anyone tell me the pro's and cons to each turbo. Thanks everybody. If this has been posted already a link would be greatly appreciated too.
DeBiase is offline   Reply With Quote
Old 12-01-2013, 09:00 PM   #2
diss7
Drives: AE86, 2x GT86, TE27
http://www.ft86club.com/forums/showthread.php?t=51820
diss7 is offline   Reply With Quote
Old 12-01-2013, 09:02 PM   #3
FA20Club.com
Drives: 2013 White Out FR-S
we use the BW turbos in some specific applications vs others. The BW turbos honestly are more well suited for goals that will require slightly higher boost levels. the garrett turbos are proven and as a Warehouse Distributor for Precision COMP etc they have the highest success rates without warranty issues. You might make a little less power than the matching Precision but it wont crap out on you early making you send it in for repair.
FA20Club.com is offline   Reply With Quote
Old 12-01-2013, 09:14 PM   #4
DeBiase
So precision has the has the highest success rate without warranty issues or are you saying being that you also distribute precision turbos you are comparing to more than just BW. And if I may ask what psi is the higher boost levels you speak of? Thanks.
Old 12-01-2013, 09:17 PM   #5
DeBiase
Originally Posted by diss7 View Post
I was on your thread but it seems no one is really responding to it anymore. And it seems people are being biased in that thread. I also didn't want to take another one of your threads and just post away in it so I made this one. Thank you tho.
Old 12-01-2013, 09:37 PM   #6
FA20Club.com
Opposite Precision has the has failure rate. Garrett best success rate. this is the reason why we use precision for more of our track specific builds and Garrett in all our production turbo kits.
Old 12-01-2013, 10:10 PM   #7
DeBiase
Ok got it. That's what I though but I was not sure. So are Precision turbos Borg Warners? Or are they separate as well? And last question do you recommend a GTX2867R or a GTX3071R for a ~325-350whp set up street car with a great mid range but still a good top end. Usually would be driven in the low to mid range with out a doubt but here and there I will take it to the track and I like to WOT on the highway often enough. Someone said the 3071 is over kill. Trying to make up my mind. I keep going back and forth. I don't want something I would be I over working nor do I want to something too much for my needs. Also when the time come I would be getting my kit from you all. I live in Broward so how could I not go with a great local name like you all.
Old 12-01-2013, 10:52 PM   #8
FA20Club.com
Precision is different from BW. Issue is i think Im the only one who has tested/tuned the multitude of turbo options. To date Ive done the GT28r GTX2867, GTX3071, GT3071, GTX3076, And all the t3t4 turbos. TheGT30 is not much laggier on spool than the GT28 on this motor. For example ive seen the 28 reach 10psi@ 3400rpm whereas the 30 reach he same benchmark @3600rpms. Theory only goes so far when selecting turbo size.I think thats more well suited to TotalHP goals.For spool characteristics depend allot on exhaust flow, manifold design, backpressure and for this motor the cam phasing settings while tuning. ive always relied more on real world testing when it comes to turbo recommendations.Someone cant tell me something if they or someone else has no precise data to back it up vs hear say. Not to many people actually run different turbos on their car to provide this data. they will only be able to tell you what their specific selection did on their own car. I would go the route of the GT3071 or GTX3071 only reason being is the 28 will make similar power but puts you closer against your knock window once you get up around 10psi.
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post:
DeBiase (12-01-2013), diss7 (12-01-2013)
Old 12-02-2013, 09:03 AM   #9
DeBiase
If its pushing out the same psi how is it approaching the knock window? Exhaust restriction or something? And in another post I saw a GTX2867 hitting 8 psi a little under 2000rpm. I'll try to find it. Is the difference in lag in your experience really so minuscule?
Old 12-02-2013, 10:47 PM   #10
DeBiase
Could you please see my above question in the post just above this one. I think you might not have seen it as I did not quote you or tag you in any way. Thank you.
Old 12-02-2013, 10:49 PM   #11
DeBiase
Mostly the knock question. You have answered the other questions in other posts and threads since yesterday.
Old 12-02-2013, 10:52 PM   #12
FA20Club.com
Youll generate less KR on larger turbos since you wont be making as much peak TQ in the lower rpms when you jump on the gas. You also wont have to remove as much timing up top on pump gas to yield max power either.
Old 12-02-2013, 11:17 PM   #13
diss7
The turbine inlet pressure with the gt28 will definitely make the engine knock prone, compared with the gt30.
Borg Warner S255-RS .48 FAER Forced Induction 39 05-16-2014 01:27 PM
PRE turbo kit (garrett GT3076R) BRZPDX Northwest 90 01-18-2014 10:39 AM
Borg Warner Match Bot diss7 Forced Induction 15 09-28-2013 10:13 AM
FS: Garrett T04e 50 and 60 trim mrk1 Engine, Exhaust, Bolt-Ons 2 05-14-2013 06:45 AM
Borg Warner 8374 vs Garret GTX35R Z3D Forced Induction 5 02-27-2013 09:27 AM
