Old 01-06-2014, 04:01 PM   #1
customfab87
customfab87's Avatar
Drives: 2014 FR-S 6MT
OEM Tires vs Dunlop Direzza ZII
Replaced the OEM tires at 100 miles. The Dunlops have over an inch wider tread width at the same tire size! Their OD seems to be smaller than stock as well. Weight is 22lbs, so approx 2lbs heavier than OEM. Only major downside is that they are louder on the freeway. Not R888 or mud tires level, but noticeable. I'll upload "after" photos tonight. Still have to process those in Lightroom.
Cheng
customfab87 is offline   Reply With Quote
The Following User Says Thank You to customfab87 For This Useful Post:
Juvenile (01-06-2014)
Old 01-06-2014, 05:16 PM   #2
wparsons
wparsons's Avatar
I'm running 225/45/17 Z2's and they're fantastic. They're definitely not quiet, but well worth the noise for the grip.
flickr
Old 01-06-2014, 05:39 PM   #3
PrDarkKnight
Director of Awesome!! :)
PrDarkKnight's Avatar
Drives: Scion FR-S
can you upload a pic with that size? that is the size I want cause i like the "meaty" look
Life is all about the ride, so go full throttle baby!!
[SIGPIC][/SIGPIC]
PrDarkKnight is offline   Reply With Quote
Old 01-06-2014, 06:14 PM   #4
wparsons
wparsons's Avatar
I don't have any shots that show off the width really...
flickr
Old 01-06-2014, 06:30 PM   #5
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Which rims are those?
Carlitoz3 is offline   Reply With Quote
Old 01-06-2014, 06:42 PM   #6
customfab87
I believe those are RPF1's. I want to save up for a supercharger before I spend money on RPF1's so I just chose to stick with the stock wheels for now. Therefore the widest I could fit was 215's.
The minimum wheel width for 225's is 7.5". You can physically fit a 225 on the stock wheels but you'll end up with the exact same tread width as a 215 since you're squeezing the tire.
Carlitoz3 (01-06-2014)
Old 01-06-2014, 07:41 PM   #7
wparsons
wparsons's Avatar
^^ Not 100% true... running a narrower rim doesn't actually change the tread width, but it does change how the tire reacts to cornering forces. A narrower wheel will make the tire have a bit less grip, but it will break loose more progressively. That said, I wouldn't put a 225 ZII on a 7" wheel either
As for my wheels, they're 17x8 +45 RPF1's.
flickr
Old 01-06-2014, 08:19 PM   #8
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Is it just me or does this tire look like a water collecting death trap. Whenever I see groves that dont exit to the edge of the tire I imidiately think of nightmarish hydroplaning.
headlikeahole is offline   Reply With Quote
Old 01-06-2014, 10:53 PM   #9
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Hydro planing results from water lifting the center of the contact patch first. The exit grooves need to reach the center of the contact patch. It doesn't matter if they reach the edges. Counterintuitive but this interesting fact has been known since the 50's at least.
The most effective anti hydro planing treads are simple circumferential grooves.
Suberman is offline   Reply With Quote
Old 01-07-2014, 12:37 AM   #10
headlikeahole
Yes I understand how tires work. Its a visual thing, it just looks wrong. This is made even worse by the tread being cone shaped, it looks like water will be forced into the dead end.
Old 01-07-2014, 01:49 AM   #11
customfab87
After Photos
Old 01-07-2014, 02:20 AM   #12
RFB
RFB's Avatar
Drives: FRS
Just wait !
When they heat up they stick like glue !
I am addicted - I buy a set EVERY year (they turn into wood after a season)-
Noise be damned - turn up the stereo !
CERBERUS
RFB is offline   Reply With Quote
Old 01-07-2014, 07:53 AM   #13
wparsons
wparsons's Avatar
They look worse than they are, I daily drive mine and have had zero issues in pouring rain at highway speeds.
flickr
Old 01-07-2014, 10:16 AM   #14
Suberman
So F1 intermediate tires look wrong?
That tread pattern is a reduced version of the tread pattern you find on rain tires.
Those grooves are optimized for water evacuation given the design purpose of those tires. Tread is only required for standing water (or snow). No tread at all is best for anything else.
Enkei RPF1 17x9 +45 with Dunlop Direzza Sport Z1 255 40 R17 & Moto-spec RS*R Sports-i djjd42 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 47 05-04-2015 05:28 PM
FS: Dunlop Direzza Z2 225/45/17 Mounted on Stock Wheels tg_1981 Wheels and Tires 6 07-30-2013 08:12 AM
Dunlop Direzza ZIIs GregV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-17-2013 08:38 AM
Dunlop Direzza slippery when cold CHOPPER Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 10-18-2012 04:26 PM
Yokohama ADVAN Neova AD08 vs. DUNLOP DIREZZA Star Spec z1 gmookher Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-13-2012 10:18 AM
