Old 10-12-2012, 10:33 AM   #1
CHOPPER
Drives: FRS
Dunlop Direzza slippery when cold
Anyone know proper P.S.I for the FRS ?
Mine seem to take forever to stick on a cold autumn day.
CHOPPER is offline   Reply With Quote
Old 10-12-2012, 10:38 AM   #2
cnk
Drives: '13 DGM BRZ Limited
They are slipping because they are summer tires. If your temps are near freezing, you need to swap to winter tires before you crash on those summer tires.
cnk is offline   Reply With Quote
The Following 3 Users Say Thank You to cnk For This Useful Post:
@Art_Mighty (10-18-2012), CBR600RR (10-12-2012), SkAsphalt (10-18-2012)
Old 10-12-2012, 10:40 AM   #3
gmookher
i'm running 31 front and 30 rear
gmookher is offline   Reply With Quote
Old 10-12-2012, 11:06 AM   #4
Mitch
form follows function
Drives: RIP '13 BRZ
I've got 255/40 crammed onto 17x8s, so I'm running 40psi all around.
Mitch is offline   Reply With Quote
Old 10-12-2012, 11:26 AM   #5
SpeedmasterBRZ
Drives: Pearl BRZ Limited
If they are Z1 star specs they are only rated down to 50 degrees. Any less than that they will not stick. They dont even reccommend storing them in freezing temps.
SpeedmasterBRZ is offline   Reply With Quote
The Following User Says Thank You to SpeedmasterBRZ For This Useful Post:
CHOPPER (10-12-2012)
Old 10-12-2012, 11:38 AM   #6
dsgerbc
Drives: BRZ(sold), STI
Lol, who could've thunk...
dsgerbc is offline   Reply With Quote
Old 10-12-2012, 11:41 AM   #7
CHOPPER
Drives: FRS
Thanx !
Yep - Happens at just below 50. They do stick after about 20 minutes of running though.
Old 10-12-2012, 11:45 AM   #8
CHOPPER
Drives: FRS
SOFT !
Hows your gas mileage ?
Old 10-12-2012, 11:47 AM   #9
SpeedmasterBRZ
Just be careful. I totalled a track prepped 09 STi with star specs in near 50 degrees temps due to loss of traction. Even though they rate them near 50 degrees doesnt mean that it is wise to. lol.
Old 10-12-2012, 12:02 PM   #10
gmookher
27mpg ish stock tune vs 24.5 mpg on stg1(driving like a maniac)
not bad since I have lighter wheels and heavier tires than stock, and grippier
side wall plenty stiff at these pressures
most of my driving is up at speed, once they warm up, pressures end up higher. I would advise 2 psi higher for the local driver or someone who does mixed driving. Everything is 80mph p to 120mph for these psi settings, great for tracking in the heat.
Old 10-12-2012, 12:28 PM   #11
driver01
Drives: brz 13
Burned...
driver01 is offline   Reply With Quote
Old 10-12-2012, 12:38 PM   #12
Im_SPEED
Drives: FRS hot lava
im running 35psi Front and 29psi rear. on 245. the star specs need to be warm form them to work the best not as hot as the XS (180f) but not as cold as the R1R(Fresh out of the Freezer j/k)
Im_SPEED is offline   Reply With Quote
Old 10-12-2012, 02:11 PM   #13
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I may need to mess with my PSI. I'm running 35 all around on 245s 17x9.
Thanks for the heads up about the 50 degrees. It doesn't get cold like htat all the time in south texas, just have to take it slow.
F1point4 is offline   Reply With Quote
Old 10-12-2012, 04:23 PM   #14
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Buy winter tires or pay your insurance deductable.
seven is offline   Reply With Quote
Enkei RPF1 17x8 Gold + Dunlop Star Specs 255/40/17 on SWP Premium Mitch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 01-08-2014 10:50 PM
Dunlop Star Spec anyone do yet ? rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 03-15-2013 07:29 AM
Yokohama ADVAN Neova AD08 vs. DUNLOP DIREZZA Star Spec z1 gmookher Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-13-2012 10:18 AM
D1 Grand Prix Round 1 Photos from Odaiba - Slippery When Wet shawrf1 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 04-26-2012 01:39 AM
