Old 01-06-2014, 11:17 AM   #1
Vten
Drives: Too heavy
2pc welded to 3pc conversion or get a different wheels ???
got these wheels for a killer deal, they're 5x120 18x9 et38 , 72.56 hub. They're the Iforged brand 2pc welded.
should I go to a 3 pc conversion ? basically cut the barrels and take and machined the center, then add another inch to the rear barrel, thatll make the backspace to 7.5" versus 6.5" at this time ( from +38 to +60 ), maybe a step lips front if possible ...and then use an inch wheel adapter to fit onto the brz .... or just sell those back and get a custom build CCW 18x10s ?
after the complete job , itll cost me about $2500 ( wheel cost included) vs $4000 for the brand new CCW ...
which one should I do ??
thanks Guys for the advice.
Vten is offline   Reply With Quote
Old 01-06-2014, 11:19 AM   #2
wlwarfield
VTECLOL
wlwarfield's Avatar
Drives: 2011 STi & 2013 F150 SVT Raptor
Buy new wheels
follow me on Instagram @wlwarfield
OFFICIAL Texas BRZ, FRS, GT86 Facebook Page
OFFICIAL NM86CLUB Facebook Page
2011 Subaru Impreza WRX STi sedan
2013 Ford F-150 SVT Raptor
wlwarfield is offline   Reply With Quote
Old 01-06-2014, 12:06 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Buy new wheels... I don't see why 2-piece welded wheels needed bolted rivets to begin with.
-alex
Old 01-06-2014, 12:38 PM   #4
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Add the inch to the outside lip so it would lower the offset by 23.4mm instead of increasing the offset. Also since you are adding, why don't you just add 2.5 inches and be a man
I didn't see the PCD was going to be wrong anyways... so just sell them and buy something else.
irax is offline   Reply With Quote
Old 01-06-2014, 12:59 PM   #5
Vten
Drives: Too heavy
I won't add the front lip, but planning to add an inch to the rear to increase the offsets . 25mm 5x100 to 5x120 will be used .... That's the plan. I'm trying to get the +35-40 after the adapter added in
Old 01-06-2014, 07:11 PM   #6
Vten
Drives: Too heavy
Went to a local wheel restoration shop and got quoted for $5-600 for each wheels converted onto a true 3pc , then add the labor to mill the face out $200 , and still need to get the wheels adapter for $250 ... Which is close to $3000 not including the wheel price .
Most likely ill be selling these wheels and order a brand new set from CCWs
Thanks guys for the advices .
Old 01-06-2014, 08:45 PM   #7
SpeedR
First86 / boat thief
Drives: MKIV Supra
I have CCW on my supra new barrel 1/2s from CCW only cost about $150 a piece.
SpeedR is offline   Reply With Quote
Old 01-06-2014, 09:38 PM   #8
Vten
Drives: Too heavy
$150/barrel ? From ccw directly ?
I'll call them tomorrow to find out ! ... I like how this wheel look ...that's the first reason I got them in the first place ... If they're really $150/barrel , times 8 =$1200 , I may keep this wheels and go on with it.
Old 01-06-2014, 11:03 PM   #9
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
The fasteners may not be in the same position. It may (read: will probably) be more work than it's worth. Best bet is to buy new wheels.
New CCW's are really 4k? I thought they were around $700 a wheel?
slicktop is offline   Reply With Quote
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
E85 conversion ender2664 Engine, Exhaust, Transmission 6 09-15-2013 10:58 PM
Stock exhaust tips: bolt-on or welded? Fast_Freddy Engine, Exhaust, Transmission 3 06-13-2013 05:34 PM
jdm conversion here it is jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-28-2012 02:26 AM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
