Old 01-03-2014, 10:35 AM   #1
Turn in Concepts
Turn in Concepts's Avatar
HVT Coilovers COMING SOON!
We just launched our presale for GD Impreza HVT Coilovers.
What does this mean for you BRZ and FR-S guys and gals? HVT is in the works with coming out with this same version coilover for you.
While we do not have exact specs on these coilovers just yet, we do expect to see a very similar coilover at a very similar price point.
He is some information on the GD Impreza version:
That's right, the BEST coilover under $1000....under $900 actually.
Years of damper testing, building, supply, service and support from
a high end damper manufacturer has lead to the creation of the very
best coilover available at the sub $1000 price point.
Hanchey Vehicle Technologies (HVT) has been involved in the design and
distribution of high quality suspension components for years. They have
created and supported some of the best dampers used in applications
from street driven daily drivers to Grand Am race cars. The downside to
some of these dampers is the price which in the past has typically started
at $2500 and gone up from there. For the first time they have turned their
attention to the lower cost market to develop a suspension system for the
"everyman" car.
Using vast production and technological resources they have been able to
produce a set of coilovers designed for street use with the best ride comfort,
handling and longevity in mind. Through proper damper engineering the
damping profile has been designed for these three components on the specific
vehicle application for which they are sold. This means that each damper is
designed specifically for the intended car; there is no one shock for all with
different mounting tabs to make them work. This means the ride is
performance oriented which still be supple. They could be described as being
"3 series" like in feel.
Many people have heard of Turn in Concepts in relation to suspension components
for Subarus. We have been selling suspension related items to Subaru owners like
you for 10 years and have brought many of the popular suspension brands to you
first. We ONLY sell what works! If we don't believe in it and run it on our own
person cars we WILL NOT SELL IT! This is the first set of coilovers we have ever
sold that is under $1000 as it is the first set in that price range that we believe
in and would put our name behind.
Specs:
Subaru Applications - 02-07 WRX and STI (5x100 and 5x114.3)
Max Stroke - Front 5.75" Rear 6.5"
Spring Rate - 4kf/m (225#/in) front and rear, helpers included
Bodies - Steal with rust proof coating
Tophats compatibility (not included) - Stock, Group N, HVT, MSI, Whiteline
Valving - specifically designed for the GD chassis for comfort and performance
Damping - Fixed (you don't need adjustment when the damping is this good)
Brake line Brackets welded to bodies
Warranty - 1 year parts and labor, rebuildable in the US
Here's a review from a tester.
These are Hanchey Vehicle Technologies new height only adjustable coilover for 05-07 WRX STi.
These include all 4 dampers, main springs, and tender springs. This new coilover option is replacing
the Swift SpecR/Feal revalved OEM strut setup on my 2005 STi. I used Whiteline Com-C front top
hats and OEM top hats in the rear. Other relevant mods are Whiteline 22mm sways front and rear.
Out of the box, the steel bodies look very nice with solid lower knuckle mounts. The rear upper holes
are slotted to allow for additional camber adjustment when using standard upper mounts. All brake
hose and ABS brackets are accounted for on the bodies. It's nice to see a coilover at this price
include tender springs and isolators to keep the spring in place during suspension droop scenarios.
On to the ride quality. I've got to say, very impressed right from the get go. To keep the evaluation
as fair as possible I've set the ride height and alignment to mimic that of the SpecR/Feal setup.
For real road situations, these things are fantastic. The damping is very well matched to the springs.
No bounce during regular driving, no windshield shattering reaction to square edged bumps. No
skittering across the pavement as the suspension fights to keep the tires planted over expansion
joints and pavement patches through sweeping corners. On the road and highway, the HVT's have
a very comfortable ride for a suspension using linear rate springs. Buck for buck, there is not a
comparably priced coilover I've tested before that can compare. The SpecR/Feal setup was great
for what it was, but I always found myself trying to find a way to get rid of the progressive rate
spring slop inherent in OEM style spring replacements. Although the base level BC's, Apex'i, and
other common coils have adjustable damping I've never found it to be of much use. Every other
cheap single adjustable coilover I've ever setup has had a poor split between compression and
rebound. It seems that if I soften the dampers enough to give a comfortable compression feel, the
rebound adjustment feels overwhelmed as the vehicle bounces down the highway and responds
unpredictably over irregularities in corners. Stiffen the damper back to the point where rebound
seems to be in check and now the car feels dead and unsprung from a compression standpoint.
Some people don't feel comfortable adjusting their dampers themselves as they don't want to
"make things worse". Some people just have no idea what they're doing so they twist knobs until
things feel acceptable. These take the guess work out of the equation and don't leave you
wondering why you can't seem to find a sweet spot with that knob. Bottom Line: Compared to
your average $1k coilover these are leagues better for people whose concerns extend beyond
slamming their car. Race car stuff? No. But for 90% of people who daily drive and weekend warrior
their STI this is an excellent place to start. For those that will inevitably ask, yes, they get low.
Turn in Concepts is offline   Reply With Quote
The Following 4 Users Say Thank You to Turn in Concepts For This Useful Post:
CARNZ (01-04-2014), chanomatik (01-06-2014), Jive Turkey (06-19-2014), Proof (01-05-2014)
Old 01-03-2014, 11:42 AM   #2
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
Interesting. I'm anxious to to see the rates for our application.
funbeatsfast is offline   Reply With Quote
The Following User Says Thank You to funbeatsfast For This Useful Post:
Turn in Concepts (01-03-2014)
Old 01-03-2014, 08:52 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
I don't know much about shock dynos, well to be honest, I really only know enough to know that is a shock dyno. So this is an honest question to a vendor I respect, I just don't know how to phrase it without sound like a ****.
Can valuable information be gleaned from a shock dyno with no numbers on it?
I'd also like to add that I'm giddy that the market is starting to notice that there is a market for this. It has returned some of my faith in humanity.
The Following 3 Users Say Thank You to Calum For This Useful Post:
circuithero (01-04-2014), DriftEightSix (03-04-2014), Thorpedo (01-03-2014)
Old 01-04-2014, 09:58 AM   #4
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Are they rebranded KW with similar calibration to the V1 (and ST) or are these built by KW to HVT's own spring/damper specifications?
Fizz is offline   Reply With Quote
Old 01-04-2014, 07:58 PM   #5
CARNZ
CHECK ENGINE
Drives: 2004 STi
According to TiC from their NASIOC post...
Originally Posted by Turn In Concepts
They are not made by KW so quite a bit different. They are designed and prototyped in house by HVT. They are better than zinc coated in that the coating applied is more similar to the KW INOX coating.
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 01-04-2014, 08:27 PM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
But looking at the coilover it's strikingly similar to the KW V1, ST, RCE units
Old 01-06-2014, 09:31 AM   #7
Turn in Concepts
I do see some similarities between these and KW branded coilovers, but the fact remains they are different and not made by KW.
These ride a bit more comfortably than the ST and KWv1's I have driven, but do not have any loss in performance.
The units were specifically left off the graph. That is to give you an idea of the characteristics of the valving, but is not designed to allow other to copy. Seeing any kind of a damper plot in this price range is rare.
The Following 3 Users Say Thank You to Turn in Concepts For This Useful Post:
Calum (01-06-2014), chanomatik (01-06-2014), SkAsphalt (02-12-2014)
Old 01-06-2014, 10:46 AM   #8
yohan04
yohan04's Avatar
Drives: Your sister
Will there be higher spring rate options?
yohan04 is offline   Reply With Quote
Old 01-06-2014, 02:30 PM   #9
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Subscribed. Will be watching closely...
Old 01-06-2014, 02:32 PM   #10
Turn in Concepts
We do not know the spring rates of the FR-S/BRZ version yet so I can not answer that question.
Old 01-06-2014, 02:38 PM   #11
OrbitalEllipses
Drives: Attitude
Plastic lock rings?
Old 01-09-2014, 11:15 AM   #12
Turn in Concepts
Plastic lock rings?
No they are metal.
The Following User Says Thank You to Turn in Concepts For This Useful Post:
OrbitalEllipses (01-09-2014)
Old 02-12-2014, 03:31 PM   #13
funbeatsfast
Drives: '13 FR-S
Don't mean to sound impatient, but any word on these?
Old 02-12-2014, 03:52 PM   #14
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
Interested to see how these compare to ST.
rcm47 is offline   Reply With Quote
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
>>>>>>>WANT HIGH-END COILOVERS? LOOK HERE ~ New ST Coilovers l KW l Racecomp l Ohlins Circuit Motorsports Brakes, Suspension, Chassis 230 02-17-2016 12:01 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 03:02 PM
M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS AMPLIFIED MOTORSPORT Brakes, Suspension, Chassis 0 08-16-2012 02:45 AM
