HVT Coilovers COMING SOON!
We just launched our presale for GD Impreza HVT Coilovers.
What does this mean for you BRZ and FR-S guys and gals? HVT is in the works with coming out with this same version coilover for you. While we do not have exact specs on these coilovers just yet, we do expect to see a very similar coilover at a very similar price point. He is some information on the GD Impreza version: ![]() That's right, the BEST coilover under $1000....under $900 actually. Years of damper testing, building, supply, service and support from a high end damper manufacturer has lead to the creation of the very best coilover available at the sub $1000 price point. Hanchey Vehicle Technologies (HVT) has been involved in the design and distribution of high quality suspension components for years. They have created and supported some of the best dampers used in applications from street driven daily drivers to Grand Am race cars. The downside to some of these dampers is the price which in the past has typically started at $2500 and gone up from there. For the first time they have turned their attention to the lower cost market to develop a suspension system for the "everyman" car. Using vast production and technological resources they have been able to produce a set of coilovers designed for street use with the best ride comfort, handling and longevity in mind. Through proper damper engineering the damping profile has been designed for these three components on the specific vehicle application for which they are sold. This means that each damper is designed specifically for the intended car; there is no one shock for all with different mounting tabs to make them work. This means the ride is performance oriented which still be supple. They could be described as being "3 series" like in feel. Many people have heard of Turn in Concepts in relation to suspension components for Subarus. We have been selling suspension related items to Subaru owners like you for 10 years and have brought many of the popular suspension brands to you first. We ONLY sell what works! If we don't believe in it and run it on our own person cars we WILL NOT SELL IT! This is the first set of coilovers we have ever sold that is under $1000 as it is the first set in that price range that we believe in and would put our name behind. Specs: Subaru Applications - 02-07 WRX and STI (5x100 and 5x114.3) Max Stroke - Front 5.75" Rear 6.5" Spring Rate - 4kf/m (225#/in) front and rear, helpers included Bodies - Steal with rust proof coating Tophats compatibility (not included) - Stock, Group N, HVT, MSI, Whiteline Valving - specifically designed for the GD chassis for comfort and performance Damping - Fixed (you don't need adjustment when the damping is this good) Brake line Brackets welded to bodies Warranty - 1 year parts and labor, rebuildable in the US ![]() ![]() ![]() ![]() Here's a review from a tester. These are Hanchey Vehicle Technologies new height only adjustable coilover for 05-07 WRX STi. These include all 4 dampers, main springs, and tender springs. This new coilover option is replacing the Swift SpecR/Feal revalved OEM strut setup on my 2005 STi. I used Whiteline Com-C front top hats and OEM top hats in the rear. Other relevant mods are Whiteline 22mm sways front and rear. Out of the box, the steel bodies look very nice with solid lower knuckle mounts. The rear upper holes are slotted to allow for additional camber adjustment when using standard upper mounts. All brake hose and ABS brackets are accounted for on the bodies. It's nice to see a coilover at this price include tender springs and isolators to keep the spring in place during suspension droop scenarios. On to the ride quality. I've got to say, very impressed right from the get go. To keep the evaluation as fair as possible I've set the ride height and alignment to mimic that of the SpecR/Feal setup. For real road situations, these things are fantastic. The damping is very well matched to the springs. No bounce during regular driving, no windshield shattering reaction to square edged bumps. No skittering across the pavement as the suspension fights to keep the tires planted over expansion joints and pavement patches through sweeping corners. On the road and highway, the HVT's have a very comfortable ride for a suspension using linear rate springs. Buck for buck, there is not a comparably priced coilover I've tested before that can compare. The SpecR/Feal setup was great for what it was, but I always found myself trying to find a way to get rid of the progressive rate spring slop inherent in OEM style spring replacements. Although the base level BC's, Apex'i, and other common coils have adjustable damping I've never found it to be of much use. Every other cheap single adjustable coilover I've ever setup has had a poor split between compression and rebound. It seems that if I soften the dampers enough to give a comfortable compression feel, the rebound adjustment feels overwhelmed as the vehicle bounces down the highway and responds unpredictably over irregularities in corners. Stiffen the damper back to the point where rebound seems to be in check and now the car feels dead and unsprung from a compression standpoint. Some people don't feel comfortable adjusting their dampers themselves as they don't want to "make things worse". Some people just have no idea what they're doing so they twist knobs until things feel acceptable. These take the guess work out of the equation and don't leave you wondering why you can't seem to find a sweet spot with that knob. Bottom Line: Compared to your average $1k coilover these are leagues better for people whose concerns extend beyond slamming their car. Race car stuff? No. But for 90% of people who daily drive and weekend warrior their STI this is an excellent place to start. For those that will inevitably ask, yes, they get low. |
| The Following 4 Users Say Thank You to Turn in Concepts For This Useful Post: |
#2 |
Drives: '13 FR-S
Interesting. I'm anxious to to see the rates for our application.
| The Following User Says Thank You to funbeatsfast For This Useful Post: | Turn in Concepts (01-03-2014) |
#3 |
That Guy
Drives: 2013 asphalt FRS MT
I don't know much about shock dynos, well to be honest, I really only know enough to know that is a shock dyno. So this is an honest question to a vendor I respect, I just don't know how to phrase it without sound like a ****.
Can valuable information be gleaned from a shock dyno with no numbers on it? I'd also like to add that I'm giddy that the market is starting to notice that there is a market for this. It has returned some of my faith in humanity. |
| The Following 3 Users Say Thank You to Calum For This Useful Post: |
#4 |
Senior Addict
Drives: 86 GT
Are they rebranded KW with similar calibration to the V1 (and ST) or are these built by KW to HVT's own spring/damper specifications?
#5 | |
CHECK ENGINE
Drives: 2004 STi
According to TiC from their NASIOC post...
i don't cry about crickets
#6 |
Senior Addict
Drives: 86 GT
#7 |
I do see some similarities between these and KW branded coilovers, but the fact remains they are different and not made by KW.
These ride a bit more comfortably than the ST and KWv1's I have driven, but do not have any loss in performance. The units were specifically left off the graph. That is to give you an idea of the characteristics of the valving, but is not designed to allow other to copy. Seeing any kind of a damper plot in this price range is rare. |
| The Following 3 Users Say Thank You to Turn in Concepts For This Useful Post: |
#8 |
Drives: Your sister
Will there be higher spring rate options?
#9 |
Snow Don't Hurt!
Subscribed. Will be watching closely...
#10 |
#11 |
Drives: Attitude
Plastic lock rings?
#12 |
| The Following User Says Thank You to Turn in Concepts For This Useful Post: | OrbitalEllipses (01-09-2014) |
#13 |
Drives: '13 FR-S
Don't mean to sound impatient, but any word on these?
#14 |
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
Interested to see how these compare to ST.
| Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers | b2autodesigns | Brakes, Suspension, Chassis | 818 | 09-10-2017 08:33 AM |
| Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! | No Limit Motorsport | Brakes, Suspension, Chassis | 204 | 05-26-2017 12:09 PM |
| >>>>>>>WANT HIGH-END COILOVERS? LOOK HERE ~ New ST Coilovers l KW l Racecomp l Ohlins | Circuit Motorsports | Brakes, Suspension, Chassis | 230 | 02-17-2016 12:01 PM |
| FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers | ill roller | Brakes, Suspension, Chassis | 5 | 12-14-2013 03:02 PM |
| M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS | AMPLIFIED MOTORSPORT | Brakes, Suspension, Chassis | 0 | 08-16-2012 02:45 AM |
