Old 12-30-2013, 06:05 PM   #1
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
Lack of traction
Just looking for some advise before I make any purchases but I recently went turbo and I ordered 255/40/18 for the rear and there Michelin pilot super sports. However if I go WOT even at 55 the back end just starts spinning what have my fellow power junkies done to help keep there rear end on the ground
Mathewgzlz is offline   Reply With Quote
Old 12-30-2013, 06:15 PM   #2
OrbitalEllipses
Drives: Attitude
Smooth application of throttle pedal.
Old 12-30-2013, 06:16 PM   #3
Mathewgzlz
Mathewgzlz's Avatar
Lol
Old 12-30-2013, 06:32 PM   #4
dabocx
dabocx's Avatar
Drives: Scion FRS
Cant go much wider than that on the stock body, how much power are you making?
dabocx is offline   Reply With Quote
Old 12-30-2013, 06:32 PM   #5
Mathewgzlz
Mathewgzlz's Avatar
Roughly 300
Old 12-30-2013, 06:32 PM   #6
Mathewgzlz
Mathewgzlz's Avatar
Give or take 10hp
Old 12-30-2013, 06:56 PM   #7
onefitz
Drives: 13 GBS BRZ
Lightweight car with a lot of power on street tires. Gonna have to be pretty easy with the throttle modulation or go to a street radial.
Wouldn't happen to know how much torque would you? Breaking lose from WOT in the top of the rev range or from 2500?
onefitz is offline   Reply With Quote
Old 12-30-2013, 07:20 PM   #8
Gunman
Drives: 2019 Mazda Miata RF
Try to get some anti-squat out of the rear suspension, let it squat more under acceleration?
Gunman is offline   Reply With Quote
Old 12-30-2013, 07:27 PM   #9
Mathewgzlz
Mathewgzlz's Avatar
I'll be able to tell you how much tq tomorrow and around the top end I normally don't like to speed on the street but I've been driving it pretty hard since I just got it back from my shop and if there's anything wrong with it I want to know before I drive back to nc
Old 12-30-2013, 07:58 PM   #10
SpeedR
First86 / boat thief
Drives: MKIV Supra
300hp + 55 mph + 255/40/18 PSS and "the back end just starts spinning" dose not add up!
Things to look at:
tires way over inflated?
do you have mad camber so only half your tread is on the ground?
800lbs springs with 1.5 in drop? (IE no squat)?
are the roads covered in snow, ice or lots of water?
are you dropping the clutch at max TQ to try and spin the tires?
SpeedR is offline   Reply With Quote
Old 12-30-2013, 08:24 PM   #11
mrk1
Drives: Sterling BRZ Ltd
something isn't right, you should have no issue hooking up at that speed and power.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 12-30-2013, 08:27 PM   #12
Mathewgzlz
Mathewgzlz's Avatar
Only a very very slight camber till I can roll the fenders and adjust everything
Old 12-30-2013, 08:46 PM   #13
Mathewgzlz
Mathewgzlz's Avatar
Things to look at:
I'll look into this and see if it helps thanks guys
Old 12-31-2013, 07:46 PM   #14
wparsons
wparsons's Avatar
Another thing to check is air/pavement temperatures... if the tires are too cold they won't stick well at all.
flickr
Lack of steering angle? epson1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 03-07-2017 02:00 AM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Possible fix for lack of steering angle JordanWho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-27-2013 06:51 PM
Lack of Bass elbachatero1 Electronics | Audio | NAV | Infotainment 13 07-31-2012 09:34 AM
