Old 12-27-2013, 06:42 PM   #1
effty_ac
Drives: 2013 Raven FRS
Interior Door Handle Help
I'm trying to install the red interior door handles I got from nigeljdm. I popped off the silver part of the handle and took out the 2 screws but can't get the handle to come out.
Anyone done this before?
effty_ac is offline   Reply With Quote
Old 12-27-2013, 07:42 PM   #2
effty_ac
I have found a 3rd screw, but I don't know how to get at it. The screw seems to be attaching the handle to the door. It seems like that thing the washer is resting against is a part of the door and not the handle (the handles i'm trying to install don't have that piece). You can't really see it, but it's in that washer thingy. The head points away from me and towards the door.
Old 12-27-2013, 11:37 PM   #3
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
yeah let me know how to get this off , i was planning on getting those red door handles from ebay or nigel and now I see this issue... hmm let me know if u find out how!
914_WHITE_FRS is offline   Reply With Quote
Old 12-28-2013, 01:43 AM   #4
GaN-MaN
WA 86/BRZ Club
GaN-MaN's Avatar
Drives: Toyota 86 GT MT Sonic Blue
There is a 3rd or 4th screw behind the door card. You'll have to remove the door card to get to it. Fairly simple job.
One more screw in door handle, one pop plug inner top then pull from sides to unclip and lift upwards. then unplug the electronics and disconnect the 2 door lock and handle cables.
2012 Toyota 86 Sonic Blue GT 6MT
GaN-MaN is offline   Reply With Quote
Old 12-28-2013, 09:04 PM   #5
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes, I've got the red interior grab handle, and was very easy to install if you remove the entire door card. Removal of the door card itself is also pretty simple, there are some DIY instructions in here somewhere....follow that and you'll be fine.
Fizz is offline   Reply With Quote
red door handle inserts abutterman Cosmetic Modification (Interior/Exterior/Lighting) 4 08-04-2015 08:10 PM
door handle/pull squeaks NRG x FRS Issues | Warranty | Recalls / TSB 1 11-27-2013 09:38 PM
Door handle replacement cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 5 07-18-2013 03:07 PM
Door handle replacement cslntuee DIY (Do-It-Yourself) Guides 1 07-17-2013 09:52 PM
Door Handle cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 11 03-24-2013 02:49 AM
