Drives: Toyota GT86
Drive shaft play
Is this amount of play normal on drive shaft ? my car only done 3,000 miles.
Never been to a track before or did any hard launch. [ame]http://youtu.be/j2RyiYZLEDw[/ame] Please advise |
Normal. This is the play that allows cars to rock back and forth when parked in-gear and the parking brake not engaged. To eliminate this play, the gears would have to be meshed so tight against each other they would wear out super fast.
Drives: Toyota GT86
Ic, but any idea why every time when i change gear there is like a metal knock sound ? sounds like the gear slapping or something. So I'm wondering is it because of the play in the shaft causing the sound ?
Thupercharged
I get this this too depending on how I shift. Seems normal, I had the same exact situation in my old BMW... rear end had about the same amount of play in it as in the video shown, shifting into first from a stop would result in a muffled clunk. Was normal
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
Drives: FR-S 6MT
This is why you just don't want to dump the clutch during a hard takeoff..
You Always want to take up this slack so you don't snap and break things.. |
| Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 08:09 PM |
| A/T Carbon Fiber Drive Shaft | Freeman | Engine, Exhaust, Transmission | 14 | 09-24-2013 04:37 PM |
| How much can stock drive shaft handle?? | Argento_FR-S | Forced Induction | 24 | 06-01-2013 07:54 PM |
| Does FRS come with Carbon drive shaft? | STi88 | Engine, Exhaust, Transmission | 30 | 07-30-2012 01:40 PM |
