Drives: 23 BRZ
Fuel Injectors, are they supposed to rotate around?
I just swapped the OEM fuel injectors for these FIC 770cc injectors. Are they supposed to rotate around like this (see video below)? The OEM injectors did not. There isn't any play if I try to move them up or down, they just seem to rotate on the rubber washer/bushing.
PN 177-0770H [ame]http://youtu.be/soEI-CDG6no[/ame] |
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
If you used lube on the O rings(hope you did, looks like you did) they will spin. Very normal. No issues will be had. The OEM injectors didn't due to the fact the lube was gone.
| The Following User Says Thank You to MPI_Jack For This Useful Post: | rb6freak (12-23-2013) |
Drives: 2013 White Out FR-S
The FIC dont use the oem locking clips so they will swivel but the oring seals them just fine thats normal.
| FS: Slightly Used BRZ/FR-S Fuel Injector Clinic (FIC) 540cc injectors | Area86 | Engine, Exhaust, Bolt-Ons | 6 | 01-23-2014 04:21 PM |
| Asking for $275 OBO... FS: Bosch 500cc Injectors, SBD 290 LPH Fuel Pump | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 116 | 09-18-2013 10:19 AM |
| Wanted: Looking for stock fuel injectors | fst86frs | Want-To-Buy Requests | 1 | 09-16-2013 03:25 PM |
| At 5,000kms and fuel injectors 2 & 4 are misfiring!!! | UnLeasHer | AUSTRALIA | 55 | 11-12-2012 04:41 AM |
| Deatschwerks BRZ/FR-S Fuel Injectors! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 2 | 09-07-2012 06:29 PM |
