Drives: Asphalt grey, manual Fr-S
Vortech boost at different rpms?
Just wondering what boost should be generated at 3000rpms 4000rpms and so forth?
Also i have the max blow off valve and wondering if it needs to be adjusted to get proper boost at different rpms? Thanks |
Drives: Panda FR-S
3000rpm~2psi
4000rpm~3psi 5000rpm~4.5-5psi 6000rpm~6psi 7000rpm~8psi 7400rpm~9psi
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
| The Following User Says Thank You to Cal3000 For This Useful Post: | avishenoy1 (04-19-2016) |
Thupercharged
Bpv should need no adjustment... went from stock pulley to 3.125" pulley and the maxflow didn't seem to care much
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
Drives: 2013 White Out FR-S
The Vortech is linear in power delivery so the higher you rev the more the boost will increase.
| Vortech Supercharging System Update - More boost, more POWER! | Brian@Vortech | Forced Induction | 337 | 03-12-2016 03:42 PM |
| Rattling in 2nd or 3rd at low rpms | BigFatFlip | Engine, Exhaust, Transmission | 54 | 09-07-2015 08:54 PM |
| boost gauge vortech help | ft86me | Forced Induction | 47 | 07-06-2015 10:50 AM |
| Where are your RPMS | Dragon86 | CANADA | 13 | 07-26-2012 10:43 AM |
| RPMS!! | Spencer Strayer | Engine, Exhaust, Transmission | 82 | 09-15-2011 09:51 AM |
