Old 12-20-2013, 02:12 PM   #1
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Drop in MPG after K&N Dropin?
I just installed my K&N drop-in filter and noticed my avg MPG drop from around 29 to 25. Has anyone else seen this happen, or would think it would?
I'll be making a 6 hour freeway drive soon for the holidays, so I'll be sure to check then (to hopefully cut out changes in driving style out of the equation).
amaciose is offline   Reply With Quote
Old 12-20-2013, 02:18 PM   #2
Urmyson
I got an AFE filter and noticed the same thing. I went from 33 to 29, after a few tanks it went back up though.
Urmyson is offline   Reply With Quote
The Following User Says Thank You to Urmyson For This Useful Post:
amaciose (12-20-2013)
Old 12-22-2013, 01:15 AM   #3
cooldandani
Drives:
yeah same thing happened to me, i went from 26mpg to 22.5 with k&n drop in but i do 99% city driving
cooldandani is offline   Reply With Quote
Old 12-22-2013, 01:35 AM   #4
humfrz
Yes, please let us know the results.
humfrz
Old 12-22-2013, 01:09 PM   #5
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
My MPG dropped as well. I was at 29-ish before I installed mine, and it dropped down to 27-ish. Installed my K&N filter like 2-3 months ago I think?
It makes perfectly logical sense though. Upgrading the filter reduces air restriction, which means the car is able to intake more air. More air = more fuel = more power = less mpg.
For me, I only lost roughly 2 mpg, which wasn't/isn't noticeable. I do mostly city driving, with a little bit of highway driving here and there. I have a 6MT, and I tend to redline my car occasionally once the engine is fully warmed up (185 degree oil temps minimum).
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
Old 12-22-2013, 04:34 PM   #6
reardrv
Drives: 2013 Subaru BRZ
That's weird, I wouldn't think a high flow air filter would affect your mileage at all. I'd grab some MAF cleaner and give your MAF a few squirts. K&N's are usually significantly over oiled out of the box, you could have a dirty MAF because of this.
reardrv is offline   Reply With Quote
Old 12-22-2013, 04:41 PM   #7
archer
Drives: 2001 jeep wrangler
I put a intake on my miata and my Mazdaspeed3 and I actually gained mileage. About 2mpg in the miata and 4 in the speed3.
archer is offline   Reply With Quote
Old 12-22-2013, 04:42 PM   #8
archer
The speed3 was a full intake but the miata was just a k@n filter.
Old 12-22-2013, 05:58 PM   #9
amaciose
amaciose's Avatar
Also heard about resetting the ECU after installing new intakes. Would this be needed for a simple drop-in as well?
Old 12-22-2013, 06:59 PM   #10
FR-S Matt
Doesn't hurt. Let's the ECU learn the increased flow the filter provides.
Old 12-23-2013, 02:55 AM   #11
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
To reset the ECU you just unhook the battery for 60 seconds, is that right?
dave77 is offline   Reply With Quote
Old 12-23-2013, 03:16 AM   #12
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Sure it's not a heavier foot to feel more power or to try and hear the intake :P?
Build Thread
Instagram
Old 12-27-2013, 01:51 AM   #13
Robert95g
Drives: 2013 FR-S Whiteout
Ok how are all of you averaging this high of a number? Im lucky to average 22, but I do drive fairly aggressive and fast... a lot.
Robert95g is offline   Reply With Quote
Old 12-27-2013, 02:34 AM   #14
humfrz
Set your red light rpm indicator at 4,000 rpm ..... and you to can get 30 mpg.....
humfrz
New TSB for RPM Drop connorlug Issues | Warranty | Recalls / TSB 24 04-25-2014 05:01 PM
Drop it Like its Hot! *Lets See Your Drop* VIXEN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 92 09-07-2013 02:53 AM
how much of a drop? five-0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-16-2012 09:10 PM
Who is going to buy the FRS DROP DROP Shop? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-18-2012 05:45 PM
TRD Drop in AF feldy Engine, Exhaust, Transmission 2 06-05-2012 08:40 PM
