Old 12-17-2013, 07:06 AM   #1
inductforce190
inductforce190's Avatar
Drives: 2013 raven FRS
anyone useing the Hotchkis Stage 1
so ive been thinking about maybe getting the Hotchkis stage 1 kit on fa20club just wondering if anyone else is useing this kit and would they recommend it?
thanks
inductforce190 is offline   Reply With Quote
Old 12-17-2013, 11:10 AM   #2
MAPerformance
Drives: Asphalt FRS
I have the Hotchkis springs on my car, and I absolutely love them. I don't have that full kit however. But I can't see why that wouldn't be a great option for a street/autoX car.
MAPerformance is offline   Reply With Quote
Old 12-17-2013, 12:48 PM   #3
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Did you have to buy any extras to correct camber? I plan on getting the Hotchkis springs as they're suited to the stock dampers. I hope to not throw more money into the setup other than getting crash bolts for the front to camber in some 17x9 +35 245/40/17 tires. Would that be okay? How much static camber in the rear did you get after the Hotchkis spring install?
Thanks.
hmong337 is offline   Reply With Quote
Old 12-17-2013, 01:05 PM   #4
MAPerformance
Drives: Asphalt FRS
Thanks.
I actually do not know yet. I plan on throwing it on the alignment rack once we get the turbo completed. I too am running 17x9 wheels and tires. I haven't noticed any difference what so ever in the way it drives, but I am curious to see if any adjustments need to be made.
Old 12-19-2013, 02:30 AM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I don't have hotchkis stage 1 for our car, but I had hotchkis springs/sways on my SRT-4 and LOVED the way it handled
Old 12-20-2013, 01:32 PM   #6
inductforce190
Ok thanks for the feed back guy they are on order ill let you know how it works out
Sent from my GT-I9505 using Tapatalk
Old 07-10-2014, 06:28 AM   #7
BRZ?
Drives: 2014 SWP 6MT BRZ
His did this work out for you? I'm thinking of picking up this kit as well
2014 SWP 6MT BRZ Limited
Diode Dynamics Door, Trunk, Dome, Vanity, License Plate and Side Marker LEDs
GrimmSpeed Plate Relocation
BRZ? is offline   Reply With Quote
Old 07-10-2014, 07:26 AM   #8
aschnell
I have the springs on my car with stock dampers. I like them. I have some 18x8.5 +45 rims 245 tires. I had to grind the left spring perch slightly since it was too close to the tire for my comfort. With the lower offset wheels it should be ok. I got the front crash bolts and maxed negative camber. I have been meaning to measure camber, have the gauge in the garage just never got around to it. From what I read the alignment stays within reason with these springs so i have been in no rush.
aschnell is offline   Reply With Quote
Old 07-11-2014, 05:45 PM   #9
continuecrushing
what size are your tires exactly? 245/??/18...
Old 07-11-2014, 07:10 PM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Youre going to buy something from FA20club?....really?
Old 07-11-2014, 09:53 PM   #11
aschnell
245/35-18 front and rear
Old 07-12-2014, 11:19 AM   #12
Gunman
Drives: 2019 Mazda Miata RF
I have the Hotchkis stage 1, aka springs and front and rear ARB's. I also have the Hotchkis strut tower brace. I'm not driving 10/10ths, its' just my daily driver and weekend mountain drives. That said, I love how it handles, and I have played with the ARB settings, and have noticed differences. Install was easy, I followed the how-to's on here. I have not had the alignment checked, I was waiting to let the springs settle, which they should be by now. Rear camber is noticeable, but not bad, front is less noticeable. My only alignment concern is the toe, I may add more camber to the front, once I get it on the rack, with some crash bolts.
From a daily driving view, it is stiffer, and you feel the bumps more, but the Hotchkis springs are one of the softest drop springs out there. I'm still of the soft spring/stiff bar mentality, and that's what my former boss, Bob Riley (look up Riley and Scott) suggested. The guys at Hotchkis are good to work with too, Aaron Ogawa is their lead designer, and also posts on here as @Hotchkis , very helpful regarding setup. I met John Hotchkis at the Hot Rod Power Tour open house, again, very friendly and down to earth.
Gunman is offline   Reply With Quote
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FS: [NY] Hotchkis Sway Bar set dori. Brakes, Suspension, Chassis 1 09-04-2013 02:59 PM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 01:32 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 01:39 AM
