Old 12-16-2013, 08:58 PM   #1
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
Shop Car Update - StopTech Brakes & More
We've been really busy with customer builds and PRI but we finally got a chance to get back on the FR-S for a bit. We mounted up the front Trophy Kit with 328mm x 28mm rotors which fit and look great. The rear is a bit more involved.
Fronts:
Currently StopTech only offers an even bigger rotor for the rear that has to clear the factory e-brake assembly. This is a lot of extra un-sprung & rotating mass and that's really not what we're after here. We really have no use for the factory e-brake so we decided to remove it all together. We also removed the factory dust shields because they are large steel pieces that incorporate the e-brake mounts.
We machined some hub spacers to replace the e-brake assembly (no geometry is changed) and took some measurements for the rear hat. We'll be using 322mm x 22mm rear rotors with some off the shelf hats from StopTech but well have to machine our own caliper mounts for the Trophy ST22.
Rears:
We will be offering these as a kit as soon as they are tested on track.
We've also started on our turbo kit so look out in the Forced Induction section for an update on that shortly.
Carolina Dyno is offline   Reply With Quote
The Following 2 Users Say Thank You to Carolina Dyno For This Useful Post:
DAEMANO (01-02-2014), industrial (12-17-2013)
Old 12-16-2013, 09:09 PM   #2
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Nice!
Let me know if you need some help with the track testing; I'm usually at Sebring every month
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 12-17-2013, 11:36 AM   #3
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Any chance you can weigh the complete stock rear system with the drum hardware? A few of us are curious about the weight savings possible from the rear brake setup.
industrial is offline   Reply With Quote
Old 12-17-2013, 12:19 PM   #4
Carolina Dyno
Drives: 2013
Just went back there and weighed everything. I might not have found every single piece of hardware from the stock setup but they came in at 29lbs a corner vs the StopTech setup I'll be running at 20lbs a corner.
The Following User Says Thank You to Carolina Dyno For This Useful Post:
Old 01-02-2014, 09:03 PM   #5
Carolina Dyno
Drives: 2013
We've been slammed at the shop with the holidays but I did have time to get this drawing finished up for the rear rotor hats. We should have these on hand soon and move on to the caliper mounts.
Old 01-02-2014, 10:38 PM   #6
mrk1
Drives: Sterling BRZ Ltd
Nice, I have the 328 front setup too. Id love a rear setup
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-11-2014, 06:13 PM   #7
Carolina Dyno
Drives: 2013
The rear hat is finished up and mounted. Stoptech was able to send us some lines that will fit so all we have left is the caliper bracket... and some wheels that fit.
jack43 (01-11-2014)
Old 01-11-2014, 08:09 PM   #8
mrk1
So if you make your own hats does that mean you don't need the hub spacers?
The Build Thread
Old 01-11-2014, 09:24 PM   #9
Carolina Dyno
Drives: 2013
Poor wording on my part. The "hub spacers" don't actually change any geometry. The factory dust shield & e-brake assembly are the exact same thickness. All the spacer does is replace the thickness lost by removing the dust shield and e-brake.
If you look back at the first picture the top right picture shows that assembly and the bottom left shows it being replaced by the simple aluminum spacer instead.
If that spacer wasn't there you would have to have shorter axles and the wheel offsets would change. I edited the first post to avoid confusion.
Old 01-11-2014, 09:56 PM   #10
mrk1
Oh ok alright, makes much more sense
The Build Thread
Old 01-18-2014, 10:14 PM   #11
Carolina Dyno
Drives: 2013
We've been working on the powertrain side of things for a couple days but I took a couple hours tonight and drew up the rear caliper bracket. Hopefully we can have these on the car before the end of the month!
DAEMANO (01-19-2014)
Old 01-19-2014, 08:34 AM   #12
mid_life_crisis
Drives: FR-S 10 #103 AT
Question on the e-brake delete. This is a really interesting project with no useful resale value except for owners who never drive their cars on the street. Are you planning on selling the rear wheel kits for track only use or is it just an exercise to see what happens on your own car?
Old 01-19-2014, 10:36 AM   #13
suaveflooder
Interested as well. My FRS will always be a DD, with focus slowly going toward the track after it gets paid off. Gonna need an e-brake but I LOVE this setup
suaveflooder is offline   Reply With Quote
Old 01-19-2014, 10:55 AM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
what's the capability of the 28mm kits vs the 32 mm ones when it comes to FI and track days.
NW Shop Directory: Tuners, Tinters & Audio DarrenDriven Northwest 129 10-14-2022 02:29 AM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
Swapping rear brakes to match Stoptech BBK Pneub Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-17-2013 02:01 PM
B2autodesigns Suspension and Brakes Cusco, Eibach, Tein, H&R, Whiteline and Stoptech b2autodesigns Brakes, Suspension, Chassis 44 01-17-2013 11:18 AM
AMT machine shop, sti brakes mounted. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-20-2012 08:08 PM
