| Northwest AK, ID, OR, WA |
Make love
Drives: H8R.. Not really
BrzEdit tuned by PRE people
Those of you tuned on BrzEdit by PRE. I have some info that may or may not help you. I had to recently change to a new AGM battery since my last one was discharged to death. Anyways, after swapping in the new batt, I noticed that my idle dip issues are gone (with or without A/C on). I presume that the ECU reset did the trick.
Also, I heard that Toyota/Subaru have a new TSB to address idle dip as well (ECU flash). Might be worth exploring having that fix integrated into your tune. |
#2 | |
Drives: 2013 Asphalt FRS
I'd tag Erich but idk what his tag is on here.
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
What batteries are u guys running that died?
#4 | |
Make love
![]() Besides.. I have never taken my car to the dealership. My dealership is PRE. Lol I think Erich's tag is @PRE-Erich Last edited by tech4pdx; 12-14-2013 at 04:49 PM. |
Make love
I was running the 11lb Braille, but that doesn't matter. What matters is that you should never discharge an AGM battery. They don't like that and it is very hard to bring them back to life. I bought another one (big crank, same design as Braille) for ~$70 at batterymart that is working great. I even installed the quick connect harness from my battery tender jr. to the battery terminals so that I can keep it maintained when I don't drive the car.
#6 | |
2013 Sion FRS
#7 | |
Make love
Make love
#10 |
ATM I have stock. But I wouldn't mind going smaller if I could to share weight. I canceled my order for the FT86 Speed factory battery. But my stock battery is dead... So it's a deff need to buy. Only issue I see is my 2 10's n 600w amp. Yo at FT86 wasn't sure if their battery would do the job.
2013 Sion FRS
#11 | |
Make love
http://ft86speedfactory.com/ft-86-sp...-tray-711.html http://www.batterymart.com/p-Big-Cra...FdFafgodIjsACg http://www.summitracing.com/parts/brl-2012k/overview/ It's exactly what I have. Notice the ETX14 battery at batterymart is way cheaper than the Braille (B14115), but it is the exact same battery. Don't believe the hype. There are only a few battery manufacturers and most shit is rebranded. Also, to keep your battery fresh and maintained, get the following (has one of the lowest amperage outputs at 750mA) which is very appropriate for AGM batteries (it also comes with the quick connect harness): [ame="http://www.amazon.com/Battery-Tender-021-0123-Junior-Charger/dp/B000CITK8S"]Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive[/ame] Hope this helps. Edit: I will be adding a newer gen bazooka bass tube (with the class D amp) to the stock setup soon. Not trying to get all gangsta, so I'll be happy with that. Still undecided on whether I'll get the double-ended one (2 woofers instead of 1). http://www.bazooka.com/products/mobi...ified-Tube-P41 |
#12 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#13 |
Make love
#14 | |
I mainly like keeping my speaker bass at 0 and my sub up just a tad.Bazooka tubes do a good job. I had one in a ford ranger and my buddy still rocks it after I sold it in his F250. 2 years old going strong! thx!
2013 Sion FRS
| BRZedit E85 How-To | mad_sb | Engine, Exhaust, Transmission | 9 | 04-24-2020 09:30 PM |
| BRZedit Help | Sojhinn | Software Tuning | 2 | 10-29-2013 11:40 AM |
| My SWP BRZ: light tuned- stay tuned! | Badaab | Member's Car Journals | 28 | 09-06-2013 12:35 AM |
| Portland people meet with Seattle area people before going into ForumFest 2013? | stockysnail | Northwest | 24 | 06-18-2013 06:19 PM |
| BRZedit tuned + Bolt-on parts | BRZPDX | Northwest | 35 | 05-21-2013 12:34 AM |
