Old 12-11-2013, 01:16 PM   #1
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
Suspension Question
Having a lot of trouble understanding some things about suspension. Im purchasing RCE Yellows and i know this will drop the car about 20mm. Now this should cause some "natural" negative camber all around correct? If i want to add MORE camber all around or say remove it, do i need the whiteline camber kit or can this be done with just the springs and an alignment. Now what about the OEM camber bolts. How do these differ from the whiteline kit?
TONYpepperon1 is offline   Reply With Quote
Old 12-11-2013, 01:28 PM   #2
CSG David
CSG David's Avatar
What goals and driving applications are you looking for?
Old 12-11-2013, 01:32 PM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The front will not change at all really. I had some springs that were lower than these and ended up around -.1. The rear on the other hand were ~-2.3 or so if I recall correctly.
The OEM bolts can give you about -1 up front, not sure how much they can remove since I'm only used them to add negative camber.
I never did anything with the rear. The whiteline kit there has limitations and requires bushing replacement if I recall correctly. Easier to replace control arms, but more expensive.
What do you want and what are you using the car for?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
TONYpepperon1 (03-18-2014)
Old 12-11-2013, 01:34 PM   #4
bfrank1972
Drives: 2013 FR-S Argento
We should make a thread and stick it at the top, this question gets asked a LOT.
1) Lowering the car naturally increases camber significantly in the rear due to suspension geometry.
2) Lowering the car naturally increases camber a very small amount in the front, but typically if you want any significant camber change in the front you need camber bolts, 'crash' bolts, camber plates, slotted struts, etc etc.
3) As CSG David alludes to, your suspension specs depend on what you want to do with the car (i.e. street only, street/track/autox combo, dedicated/competitive autox, dedicated/competitive track, all have different alignment requirements).
bfrank1972 is offline   Reply With Quote
Old 12-11-2013, 01:41 PM   #5
TONYpepperon1
I deff want the car set up for street use. I daily drive it 99% of the time. I just wanted to have bit of an aggressive look but not overly "stanced". It needs to practical.
Old 12-11-2013, 01:57 PM   #6
Racecomp Engineering
An alignment sticky is a good idea...
I'd recommend the factory camber bolts up front. They're cheap and will help you get the camber you want. You don't end up with a ton up front but it's enough to keep wear even and improve handling slightly.
For the rear, you can get away without adding anything, though I'm anal and would like it to be perfect...to do that you'd want adjustable rear lower control arms or the pain in the ass rear whiteline camber bushing.
- Andy
Old 12-11-2013, 01:58 PM   #7
bfrank1972
Just get some camber or crash bolts up front and get the car aligned. Some camber bolts will give you more camber than factory 'crash' bolts, but in general people tend to just 'max' them out. Anything under -2 degrees camber in the front or rear is probably fine for daily and you won't get near that with just bolts and mild lowering springs. Just make sure your toe is set correctly as it changes a bit as you lower the car.
The Following User Says Thank You to bfrank1972 For This Useful Post:
TONYpepperon1 (12-11-2013)
Old 12-11-2013, 02:07 PM   #8
bfrank1972
- Andy
Doh beat me to it.
One last thing to add which Andy talks about above, factory alignment specs, particularly camber, are notoriously uneven in these cars. Not a huge deal, but if you want even left/right camber on the rear, you'll likely need some sort of camber adjustment the rear (whiteline UCA bushings, adjustable rear LCA's, etc.) I wouldn't call it being 'anal', but just the same if you're fine with the way your car feels off the lot, you'll probably be fine with no camber adjustment on the rear
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
Racecomp Engineering (12-11-2013), TONYpepperon1 (12-11-2013)
Old 12-11-2013, 02:21 PM   #9
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
So if I wanted -1 in the front and -2 in the rear natural camber and alignment would be pretty close?
Old 12-11-2013, 02:33 PM   #10
wparsons
wparsons's Avatar
^^ In the rear, probably pretty close, but up front will be way off without something to add more camber. It'll be very close to 0 still up front even with springs.
flickr
Old 12-11-2013, 02:33 PM   #11
bfrank1972
Depends on how low you go. RCE springs have a mild drop - with those I doubt you'd get to -1 degrees camber in front and -2 degrees in the rear. Front camber doesn't change much at all when lowering, but camber bolts are cheap and easy to install - they'll get you to -1. If you want -2 natural in the rear you'll want to go with somewhere around 1" drop or a little bit more than that, and again that depends on where your car was at stock (one side might have more camber than the other). If you don't want to go that low and you want -2 degrees in the rear you'll need camber adjustability.
Old 12-11-2013, 02:52 PM   #12
You'd be close to -2 in the rear and probably a little under -1 up front.
The OEM camber bolts are like 10 bucks or less. So...get them. Very much worth it.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 12-11-2013, 05:15 PM   #13
TONYpepperon1
Originally Posted by bfrank1972 View Post
Doh beat me to it.
Well i guess this leads me into another question. Tire wear. If say i have -1 in the front -2 in the rear (with a square wheel setup) will there be a problem with tire rotation since they will now be wearing on different parts of the tire?
Old 12-11-2013, 05:37 PM   #14
BlueDubbinTDI
I thought the same thing. To avoid this ill probably rotate 3-4k miles instead of 5-7k..I really cant think of anything else, tire wear is tire wear and aggressive setups require camber.
Question for you suspension Guru's invzabomaster Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-13-2013 05:26 PM
Suspension (Coilover) Install Question crizkay Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 02-28-2013 09:17 AM
A question regarding wheel/suspension aptitude. Asterisked Accolade Tracking / Autocross / HPDE / Drifting 18 01-11-2013 12:33 AM
suspension question Bruninho8 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-14-2012 05:03 PM
BRZ vs. FRS suspension question smbrm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-12-2012 09:55 AM
