Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
The quest for a good wheel/tire setup?
I am searching for new wheels/tires and was wondering what to get because there are so many options it can be overwhelming.
Such as Staggered or Square? Tire options? 225 255? Wide or stretch tires. I know what staggered and square wheels/tires are but I don't know which would be best for my application. I daily drive the car but would like to take it to some track days and drift it and enjoy my self. Pretty much I want my car to be a sleeper. I wanted to keep similar balance and tail happiness as stock. However I did want to get bigger wheels and a flush look. (Not Hella-flush). Yes the car will eventually be dropped. I want to turbo the car in the future but it will not happen for a while. On my civic turbo and rsx I always just ran square setups but now I feel that i am in a whole new playing field. Thanks for all your help! I apologize if there have been similar threads. |
Square 225 on an 8 or 9 inch rim.
Drives: 2013 FRS, 2008 R32
Comes down to personal preference really. The best performing setup would be something lightweight, 8" wide with upgraded 215, maybe 225 rubber.
I run 9.5" wide with 265 tires. Overkill and does hinder acceleration to some (trivial) extent but I'm very content. There was a video posted where they took a stock FR-S onto a track with 215 stocks, 215's of x better tire and 225's of the same upgraded tire and the stock size upgraded tire gave the best last time. For a DD, it's not always the best performing setup, for me anyway. I want what feels and to an extent, looks the best. |
Thanks
I don't think it is a good idea to street the tires you plan to track. I would look into a street setup and have a dedicated track wheel/tire you don't use daily.
For street use I just run a staggered wheel with all seasons
Trust me, I'm the Doctor
If you're going to track, square setup. If you're going to autoX also, stay stock width & go 225/45 or 215/45 in order to stay stock legal. Enkei RPF 01's are a great choice.
After that is tire model. For tracking & daily probably an extreme performance summer that has good wear characteristic. Sent from my SCH-I535 using Tapatalk
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
Drives: '23 BRZ
Drives: GR86 / Supra MK5 MT / MR-S / Z4
as most have said before. With your reqirements, take a 8" wide rim and 225 tires. Offset something in the 35 range as long as you are on stock suspension
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
#8 | |
Drives: '23 BRZ
They tested on OEM 215/45-17 Primacy HP, 215/45-17 Dunlop Z1 StarSpec, and 235/40-18 StarSpecs. IMO they screwed up in a big way on the "upgraded" sizing, as 235/40-18s are 0.7" larger in diameter than the OEM sizing which changed the overall gearing, and no good reason to go to 18s anyway. They should have tested 245/40-17s on wider wheels as the upgraded size (same diameter as OEM). Or 245/35-18s (also OEM tire diameter) if they just HAD to go up in diameter. The wider tires did give them more lateral grip: 0.96g vs. 0.94g, 71.2mph slalom speed vs 70.2mph on the 235/40-18 StarSpecs vs. OEM sizing. But the additional weight and worse gearing reduced max track speed from 94.0mph to 92.5, and added 0.6 seconds to lap time. |
Rocket Bunny FRS
Thanks for the feed back guys. I was also thinking of having two sets of wheels. But for now ill stick with the ones i was looking at.
#10 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
Go light weight for improved performance. Just picked up some used rims 17" that weight 4 lbs less than stock. Using stock tires. I cant believe how much more responsive and just quicker the car has become. If u can find 18 that are light i guess that will be good as well. Will look better for sure but expect to drop big money as ure gonna hve to get tires with that.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#11 |
i think im gonna disagree. 9 inches is 229mm so its hardly a stretch (ignoring tires that run narrow). if you look to other platforms with infinitely more performance data, you will see that a 225 on a 9" rim is faster than a 225 on an 8" rim in every single situation. i have yet to hear why it would be different with this car. i have yet to even see the difference tested. but so far, in every comparison ive ever seen, the 9 is faster at that size.
#12 | ||
Drives: '23 BRZ
Also, it's not ONLY about absolute lap times. OP said: I daily drive the car but would like to take it to some track days and drift it and enjoy my self. Daily driver, not competing where tenths matter. Besides being a lower-performing option on 9" wheels vs. 245/40-17 and being outside tire manufacturer's recommendations for fitment, 225/45-17s on 9" will leave the wheels more susceptible to curbing due to the stretch. Rim will hit the curb way before the tire's "rim protector". And it looks dumb (subjective). For OP's usage, I'd actually still prefer 245/40-17 on 8.5" wheels. This is the street fitment I have on the front of my FD. If I were to run 225/45s on the street, I would want 7.5" wheels. Personal preference based on not being a fan of any stretchie look at all and also in order to protect the rims better against curbing. |
#13 | |
And yes, agreed. Not sure why they upped to 18's for that test. Either way, 0.6 seconds is negligible. So is the lateral grip to many for a daily driver.
#14 | |
No rice, no life
Drives: 2013 Asphalt FR-S
| Good wheel/tire set up for daily driver | Oburn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-10-2013 02:21 PM |
| WTB: Track / AutoX Wheel and Tire Setup | n8dog11914 | Wheels and Tires | 3 | 06-17-2013 06:42 PM |
| Good tire to wheel specs? | _F-R-S_ | Tracking / Autocross / HPDE / Drifting | 4 | 01-18-2013 02:03 PM |
| tire/wheel setup? | kosoku | Tracking / Autocross / HPDE / Drifting | 0 | 11-25-2012 09:53 PM |
