Old 12-07-2013, 06:45 PM   #1
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Not sure if I installed this pulley right
As the title says, I just recently bought a new Perrin crank pulley for my car and attempted to install. Installed and reinstalled just because not confident if it was done properly.
The bolt that is holding the pulley in place is kind of going back and forth, the pully itself seems to be spinning fine. And the belt tensioner pulley seems to bounce around too... Can anyone give me some advice on how this looks?
Here is a video of my installed pulley.
[ame="https://www.youtube.com/watch?v=L4fAY1Aq6pY"]https://www.youtube.com/watch?v=L4fAY1Aq6pY[/ame]
rhythmM is offline   Reply With Quote
Old 12-07-2013, 06:49 PM   #2
ML
ML's Avatar
Drives: 13 White MT FR-S
That's normal. As long as it's not leaking oil for the inside of the pulley
Old 12-07-2013, 09:09 PM   #3
rhythmM
rhythmM's Avatar
I tried torquing it again and there still seems to be some slight play with the bolt, the pulley is spinning fine though... I'm just worried about the worst case scenario.
Old 12-07-2013, 09:19 PM   #4
ML
ML's Avatar
the bolt is loose? I have about 20,000 miles on mine, and it looks exactly like your video.
Old 12-07-2013, 09:26 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
Replace the bolt. If you do, the worst case scenario is your out $10 or so for nothing. If you don't replace the bolt, the worst case scenario is it breaks, the crank gets unbalanced, you spin a couple bearings and window your block.
Calum is online now   Reply With Quote
Old 12-07-2013, 10:16 PM   #6
rhythmM
rhythmM's Avatar
Alright, for the sake of my conscience I will probably buy a new bolt and o ring to replace. Hopefully that resolves my dilemma. Thanks you guys.
Old 12-07-2013, 10:20 PM   #7
Mo707
Mo707's Avatar
nope. the same thing happened to me. when you torque it down make sure its parallel to the engine tighning the bolt wont straighten it out. mine did that so i pulled it back off and used a pry bar to keep it parallel and had my buddy torque it. it shouldnt shake like that.
Mo707 is offline   Reply With Quote
Old 12-08-2013, 12:43 AM   #8
FR-S Matt
Its fine. I wouldn't worry unless the pulley itself wobbles.
Old 12-08-2013, 12:50 AM   #9
pche
Guy on internet
Drives: Slowly
That's normal
pche is offline   Reply With Quote
Old 12-08-2013, 12:56 AM   #10
Mike86
Drives: Scion frs
Same with mine!!
Mike86 is offline   Reply With Quote
FS: Perrin Crank Pulley $100 SoCal Region. Never installed. Cal3000 Engine, Exhaust, Bolt-Ons 4 11-08-2013 10:14 PM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 03:59 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
pulley installed issue Sall Issues | Warranty | Recalls / TSB 31 08-14-2012 11:36 PM
