Old 12-04-2013, 07:46 PM   #1
nonicname returns
Drives: 4 wheels
will the new wrx engine fit the frs?
Im sure this has been mentioned before but im curious if the new 2.0DIT
would fit the frs? The turbo set up is the same as AVO so i dont think it would be too hard for it to fit?
yes it is the same engine as the frs with turbo and DI:
nonicname returns is offline   Reply With Quote
Old 12-04-2013, 08:01 PM   #2
1086
1086's Avatar
Drives: UM86 - 6MT
Is it confirmed which engine will be in the 2015 WRX? If it is the FA20, then you should know the answer... - They did say it is going to be a 2.0L @ 268bhp/258tq
1086 is offline   Reply With Quote
Old 12-04-2013, 08:11 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Fit? Yes
Wiring & ECU? GL
Oh also TMIC won't work due to how back the engine is
charged86 (12-05-2013)
Old 12-04-2013, 08:12 PM   #4
nonicname returns
Drives: 4 wheels
FA20 DIT I believe. Same as the forester. It has subarus direct injection system instead of toyotas which sucks.
Twin scroll turbo makes this beauty hit 258lb/tq at 2,000rpm.
That would totally fix the frs!
Old 12-04-2013, 10:10 PM   #5
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
Save the cash and just do the AVO kit then?
Ryuu0u is offline   Reply With Quote
The Following User Says Thank You to Ryuu0u For This Useful Post:
SkAsphalt (12-05-2013)
Old 12-04-2013, 10:52 PM   #6
DIM
What's the CR for the new WRX?
DIM is offline   Reply With Quote
Old 12-04-2013, 10:55 PM   #7
nonicname returns
Drives: 4 wheels
I know i know its just the wrx engine is designed for a turbo so it will last for ever.
All these boosted high compression stock engines in the frs will last 2-3 years and will cause a lot of problems. Its just not built for boost.
Old 12-04-2013, 10:56 PM   #8
nonicname returns
Drives: 4 wheels
I believe its 10:1 but dont quote me on that.
Old 12-04-2013, 11:01 PM   #9
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
'fit' sure, but the FB20DIT (The FB came years before the FA) isnt going to be anything near plug and play.
chulooz is offline   Reply With Quote
Old 12-04-2013, 11:08 PM   #10
JustBoostin
Drives: Asphalt FR-S 6MT
Just cause it's designed from factory with boost doesn't mean it'll last forever. A good friend of mine just had a failure in cylinder 3&4 on his 2013 WRX with 30,000km. Not a single power mod installed on it either. Not even a tune.
JustBoostin is offline   Reply With Quote
Old 12-04-2013, 11:09 PM   #11
chulooz
Registered you sir
chulooz's Avatar
The other important difference is your friend still has a valid warranty.
The Following User Says Thank You to chulooz For This Useful Post:
JustBoostin (12-04-2013)
Old 12-04-2013, 11:15 PM   #12
nonicname returns
Drives: 4 wheels
No matter how good an engine is im sure there is still a 5% failure rate.
I had an 06 wrx stage 2 that i drove like i stole for 6 years and it was flawless, never had a single issue.
Old 12-04-2013, 11:17 PM   #13
nonicname returns
Drives: 4 wheels
Why do you say FB? this is an FA.
Old 12-04-2013, 11:19 PM   #14
chulooz
Registered you sir
chulooz's Avatar
What is FA? The wrx will have a FB unless you link a source I can read?
Greatest looking engine bay/engine Rayme Other Vehicles & General Automotive Discussions 61 10-10-2015 07:36 PM
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 01:56 AM
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 08:12 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
FT 86 Engine jayjayjayjay Engine, Exhaust, Transmission 15 01-18-2011 02:22 PM
