Old 12-01-2013, 09:32 PM   #1
Iddoit2er
Drives: S
VA inspection Q
Anyone know if VA inspection checks for the orange reflectors in the front of the vehicle? I had my side markers painted, so theyre no longer orange, and no longer reflectors. I plan on getting it inspected this month at the dealership while I have my 15K maintenance done.
If so, anyone in the Tysons Corner area wanna let me borrow theirs??
Iddoit2er is offline   Reply With Quote
Old 12-02-2013, 08:35 AM   #2
infinite012
Drives: 13 DGM BRZ Ltd
I think part of the federal standards for forward lighting is that the vehicle needs (must have) amber reflectors on the front corners of the vehicle, whether they be integrated into the headlights themselves or as a separate unit.
Unfortunately, if you get a real stickler of an inspector, you will fail.
Edit: Here it is, in Table I-a of FMVSS 108 (http://www.fmcsa.dot.gov/rules-regul...49CFR571.108):
Side Marker Lamps
2 Amber
On each side as far to the front as practicable
Steady burning except may be flashed for signaling purposes. Must be activated when the headlamps are activated in a steady burning state or the parking lamps on passenger cars and MPVs, trucks, and buses less than 80 inches in overall width are activated.
infinite012 is offline   Reply With Quote
Old 12-03-2013, 06:18 PM   #3
Iddoit2er
Drives: S
Anyone know the part number for the oem side markers?
Old 12-03-2013, 07:47 PM   #4
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
Man just go to a gas station. 70% of them don't know what side markers are
I am very insecure. I have no friends. I want people to love me
Old 12-03-2013, 08:01 PM   #5
infinite012
Yeah, my experience with Fairfax County has been that if you go to a gas station (especially one of the "off-brand" stations), they won't care about minor things like that.
Dealership technicians generally know what a stock car looks like and will fail your car for whatever reasons.
Old 12-03-2013, 10:22 PM   #6
Vyk
Vyk's Avatar
Drives: Black BRZ Limited
Right from the Virginia State Inspector's Manual
http://lis.virginia.gov/cgi-bin/legp...19VAC30-70-180
"NOTE: In addition to the required clearance lamps showing to the front and to the rear, a vehicle may be equipped with side marker lamps on the side of the vehicle. When such an installation is used, all of the clearance lamps on the side except the one at or near the rear must have an amber lens. The side marker lamps on the side at or near the rear must have a red lens."
2013 Subaru BRZ Limited Crystal Black - 2011 Suzuki GSX-R 750 Blue and White - 2005 Suzuki Boulevard M50 Blue
Vyk is offline   Reply With Quote
Old 12-04-2013, 02:23 PM   #7
flais
Band
flais's Avatar
Drives: Asphalt FR-S
Clearance lamps are not relevant and federal standards only apply to manufacturers/importers. The section to look at is 19VAC30-70-200. Permissible lighting equipment. Part B:
http://leg1.state.va.us/cgi-bin/legp...19VAC30-70-200
Side marker lamps are not required. If installed they must operate and be inspected. If the bulb, socket and wiring are removed from an individual lamp unit, the unit will not be considered during inspection. This does not include wraparound tail/marker lamp assembly/lens, which is intended to perform multiple functions.
flais is offline   Reply With Quote
Old 12-04-2013, 04:38 PM   #8
Iddoit2er
Drives: S
Im pretty sure orange reflectors are required in the front of the vehicle - how they operate is secondary. My real question was if anyone thinks the inspectors look for this. It sounds like from the few inputs, that trying a gas station might yield a better result.
In any case, I would still like to get a stock pair in the likely event that I sell this car in the future. Anyone want to find a part number for me? Or trade me theirs if youve replaced them with clears? Ive got lots of little goodies for this car to trade...
Old 12-05-2013, 09:54 AM   #9
infinite012
I can trade you my OEM amber side markers next month after my inspection
Old 12-06-2013, 02:36 PM   #10
VoiD
Drives: 13 WRB BRZ
i would say it is no issue.. if you fail, i do have extra stock ones you can borrow..
VoiD is offline   Reply With Quote
MD State Inspection VuDism Mid-Atlantic 4 09-04-2013 12:00 AM
NJ Inspection Question ft86Fan NY / NJ / CT / PA 9 05-24-2013 12:55 PM
Inspection of New FR-S Still Tripped Scion FR-S / Toyota 86 GT86 General Forum 22 03-28-2013 07:19 PM
brake pad inspection sickmint79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-05-2013 09:22 PM
PIC 10K TRD Air Filter Inspection Yruyur Scion FR-S / Toyota 86 GT86 General Forum 8 10-07-2012 01:53 AM
