Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 05-24-2013, 10:00 AM   #1
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
NJ Inspection Question
I have a car that needs to be inspected but I'm not too sure whether it will pass inspection. Should I first take it to a state inspection station and see if it passes and if it doesn't then take it to a private station or should I take it to a private station first? I guess my main question is that once a state inspection station fails you, would it then be more difficult for a private station to pass you even if they would have in the first place? Thanks.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 05-24-2013, 10:14 AM   #2
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Always best to try it for free. They only test for emissions now so unless you have all the cats removed and a check engine light on, I don't think it will be an issue. The private places charge for a reason, they will give you a pass for a fee from what I've heard.
hyper4mance is offline   Reply With Quote
Old 05-24-2013, 10:19 AM   #3
cnk
Drives: '13 DGM BRZ Limited
Just keep in mind that a lot of private shops won't reinspect you if you failed the state inspection facility.
Sent from my Transformer using Tapatalk 2
cnk is offline   Reply With Quote
Old 05-24-2013, 10:20 AM   #4
ft86Fan
ft86Fan's Avatar
Thanks. My car is stock except for a different ECU that has a tune. When I hooked up my OBDII reader it shows that 2 of the monitors were not ready. Not sure why.
I guess my question is more of a generic question whether if the state inspection fails you then it is more difficult for the private station to pass you for a "fee".
Old 05-24-2013, 11:00 AM   #5
hyper4mance
ooh good to know cnk.
maybe try flashing it back to the stock tune before trying to inspect? I'm not really sure what else to do either.
Old 05-24-2013, 11:02 AM   #6
Foobar
SLO NO MO
Foobar's Avatar
NJ will pass you with two OBD2 statuses in a pending state. Any more than that and it's a fail.
Old 05-24-2013, 11:23 AM   #7
ft86Fan
ft86Fan's Avatar
Thanks. Thats good to know. I thought they only allow one monitor that is not ready.
Old 05-24-2013, 11:27 AM   #8
Foobar
SLO NO MO
Foobar's Avatar
2 is what I heard from someone who went through the process a couple of years ago, if it has changed since, I'm not sure. Admittedly, I can't find the rules online - still looking though.
Yep, you fail if you exceed 2 not ready monitors for model years 2001+ - http://www.nj.gov/dep/aqm/OBDadoption.htm
New York will fail us at 2 or more, so New Jersey is more lenient.
Old 05-24-2013, 11:30 AM   #9
cnk
Did you just flash the ECU? If so, it can take some miles before all the checks are completed.
Old 05-24-2013, 12:55 PM   #10
ft86Fan
ft86Fan's Avatar
Thanks for the research. Really appreciate it. Makes me feel better bringing the car in for inspection.
I swapped my original ECU with another ECU from the same model car that already has the flash and that was years ago. Battery was also never disconnected and I never cleared the ECU. Thats why I'm not sure why I would get the 2 monitors not ready.
Inspection of New FR-S Still Tripped Scion FR-S / Toyota 86 GT86 General Forum 22 03-28-2013 07:19 PM
NJ Inspection Questions ft86Fan NY / NJ / CT / PA 13 02-13-2013 04:33 PM
brake pad inspection sickmint79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-05-2013 09:22 PM
inspection sticker question wallace03 Off-Topic Lounge [WARNING: NO POLITICS] 6 12-02-2012 04:48 PM
PIC 10K TRD Air Filter Inspection Yruyur Scion FR-S / Toyota 86 GT86 General Forum 8 10-07-2012 01:53 AM
