Old 12-01-2013, 03:31 PM   #1
BRZ NA
Drives: WR blue
255/40/17 set up
Have you guys ever ran 255/40/17 with stock suspension and specs on the track?any fitment problems with it?thx
BRZ NA is offline   Reply With Quote
Old 12-01-2013, 04:21 PM   #2
zeppy
Drives: subaru brz-limited
I think we'll need more info to answer this. what with wheel and offset? I ran a 17x19 et38 with 255's and no issues on track.
zeppy is offline   Reply With Quote
Old 12-01-2013, 05:05 PM   #3
BRZ NA
Drives: WR blue
Like 17x9 35offset rpf1. I m concerned issues about running with stock suspension. So...
Old 12-01-2013, 06:53 PM   #4
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I run a 17x9 +35 with 255/40/17's I have no fitment issues but I am not sure if the same could be said for a car on stock suspension.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 12-01-2013, 09:35 PM   #5
fatoni
thats an awful lot of tire for a stock car.
Old 12-02-2013, 09:54 AM   #6
BRZ NA
Drives: WR blue
Anyone else?thx
Old 12-02-2013, 10:03 AM   #7
It depends on the tire you run. Not all 255/40/17 are made equal. Wider tires like the Z2 and RS3 will rub.
Old 12-02-2013, 02:00 PM   #8
BRZ NA
Drives: WR blue
Damn really? those r my top selections
Old 12-02-2013, 11:33 PM   #9
kster1
kster1's Avatar
OP, slightly off topic but you should check out the December issue of Grassroots Motorsports. They talk about the relationship of rim width and tire width in their lap time results. The conclusion was that:
"The optimal rim size for a tire is equal to, or slightly larger than, the tread width."
According to their testing, a 255 tire is not ideal for a 9" rim.
kster1 is offline   Reply With Quote
Old 12-03-2013, 03:11 AM   #10
mtsui
Drives: 135i
I'm running 255 RS3 in a 17x9+42 for track, the front can't clear with the offset so had to add 5mm spacer. the tires will rub the front sway bar when its full lock, other than that it's all good!
btw, I'm with stock suspension as well... and you ride height will look stupidly high, haha
mtsui is offline   Reply With Quote
Old 12-03-2013, 11:25 PM   #11
BRZ NA
Drives: WR blue
Thx for the input
Old 12-04-2013, 10:15 AM   #12
balance
Drives: 86 & Picanto
Curious about this.. Because I used to run the same setup (255/40/17 on 17x9) on my old track car that made roughly twice the horsepower of the twins.
balance is offline   Reply With Quote
Old 12-04-2013, 01:36 PM   #13
fatoni
well with the extra power it was probably easier for you to heat up that much tire. its looking like the stock powered frs is not able to heat up much more than a 225.
Old 12-04-2013, 01:52 PM   #14
Oh it can heat up a 255. It's just a matter of what your goals are. 225 generally yields faster lap times, but it's not always the case.
