Drives: WR blue
255/40/17 set up
Have you guys ever ran 255/40/17 with stock suspension and specs on the track?any fitment problems with it?thx
| The Following User Says Thank You to BRZ NA For This Useful Post: | Joe-G (12-19-2015) |
#2 |
Drives: subaru brz-limited
I think we'll need more info to answer this. what with wheel and offset? I ran a 17x19 et38 with 255's and no issues on track.
#3 |
Drives: WR blue
Like 17x9 35offset rpf1. I m concerned issues about running with stock suspension. So...
#4 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I run a 17x9 +35 with 255/40/17's I have no fitment issues but I am not sure if the same could be said for a car on stock suspension.
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
| The Following User Says Thank You to SubiePig For This Useful Post: | Scooby South (01-12-2016) |
#5 |
thats an awful lot of tire for a stock car.
#6 |
Drives: WR blue
Anyone else?thx
#7 |
It depends on the tire you run. Not all 255/40/17 are made equal. Wider tires like the Z2 and RS3 will rub.
#8 |
Drives: WR blue
#9 |
OP, slightly off topic but you should check out the December issue of Grassroots Motorsports. They talk about the relationship of rim width and tire width in their lap time results. The conclusion was that:
"The optimal rim size for a tire is equal to, or slightly larger than, the tread width." According to their testing, a 255 tire is not ideal for a 9" rim. |
#10 |
Drives: 135i
I'm running 255 RS3 in a 17x9+42 for track, the front can't clear with the offset so had to add 5mm spacer. the tires will rub the front sway bar when its full lock, other than that it's all good!
btw, I'm with stock suspension as well... and you ride height will look stupidly high, haha
| The Following User Says Thank You to mtsui For This Useful Post: | CSG Mike (12-03-2013) |
#11 |
Drives: WR blue
Thx for the input
#12 |
Drives: 86 & Picanto
#13 |
well with the extra power it was probably easier for you to heat up that much tire. its looking like the stock powered frs is not able to heat up much more than a 225.
#14 |
Oh it can heat up a 255. It's just a matter of what your goals are. 225 generally yields faster lap times, but it's not always the case.
| The Following User Says Thank You to CSG Mike For This Useful Post: | LOLS2K (12-06-2015) |
