Old 11-29-2013, 03:19 PM   #1
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
FR-S vs MX5 hardtop vs MR2 Spider hardtop...
Anyone driven all three?
Opinions on handling and day-to-day living?
These were my two likeliest candidates for next daily driver.
NWFRS is offline   Reply With Quote
Old 11-29-2013, 03:24 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
well, if you need two extra seats and cargo room the answer is quite clear.....
Old 11-29-2013, 03:29 PM   #3
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
I didn't need the extra room by any means. My previous cars were, if anything, smaller. :-)
Old 11-29-2013, 03:42 PM   #4
xbiker
Erect Member
Drives: 2013 Asphalt FRS
I've driven all three and I currently have a Spyder with a hard top and an FRS. The last model year that Spyders were imported in the US was 2005 and the hard tops are not that easy to find for less than $2400. For a daily driver the FRS is a better choice, IMHO.
2013 Asphalt FRS
2000 MR2 Spyder, turbo, hard top, 6sp
2012 Falcon 4-Stroke, ultralight powered parachute
2014 Husqvarna lawn tractor 46" cut, mulching kit
xbiker is offline   Reply With Quote
The Following User Says Thank You to xbiker For This Useful Post:
NWFRS (11-29-2013)
Old 11-29-2013, 04:04 PM   #5
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Between the MR2 Spider and the MX5, which was your favorite? Which one, in your opinion has the better motor? My previous daily driver was a 2nd gen MR2 and I found that it handled badly when pushed too hard. I've never driven an MR2 Spider...
...And was the hardtop worth the investment?
Old 11-29-2013, 04:21 PM   #6
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
...And did you invest in a hardtop?
Handled badly is in oversteer or understeer?
Old 11-29-2013, 04:25 PM   #7
fatoni
a hardtop isnt really going to change the nature of the mr2 or miata. the miata is going to have the least interior space of all. its also going to be the most playful imo and its by far the easiest of the three to sort out the performance. plus the foolish see them as chick cars so you dont pay the stupid fanboy taxes that you see with other used "sports" cars.
The Following User Says Thank You to fatoni For This Useful Post:
NWFRS (11-29-2013)
Old 11-29-2013, 04:32 PM   #8
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
It had a tendency to understeer, then a violent pendulum swing the other direction. I had new 15" 16lb wheels and some kind of Hankook tire. It was the only car I've owned that did that, and also the only mid-rear engine. All my other front-engine cars had a fairly forgiving "sweet spot" where you could drive them on the edge without getting into trouble. My '92 MR2 handled great until you crossed some invisible line, then there was no recovery. After a few close calls I just stopped pushing it, and I had to be especially careful in the wet. The margin for error was just too small to be any fun. :-(
"Snap oversteer" was what came up in my reading, and that pretty well describes it.
The Following User Says Thank You to NWFRS For This Useful Post:
dem00n (11-29-2013)
Old 11-29-2013, 04:37 PM   #9
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
I agree with you 100%. I've never owned a Miata but test-drove several. I would have had no problem driving one. They handle SO well. It gripes me too that they are perceived as "chick cars".
Old 11-29-2013, 04:54 PM   #10
serialk11r
Drives: '06 AM V8V Coupe
The chassis in the MR2 flexes a shitload, and I kind of doubt a hardtop would fix that, but supposedly bracing is supposed to make it a lot better. I'd say practicality is not a huge issue as far as carrying plain old luggage/bags goes, if you want to get giant packs of drinks from Costco or something then it's a problem. If you get a hardtop and then remove the softtop along with all of the plastic, then the opening to the space behind the seats becomes quite nice and usable.
Someone recently posted on Spyderchat that they removed all the plastics in the front and just stuffed suitcases against the frame. I'm planning to add gas struts to the frunk so I don't have to use the stick to hold it up every time, and then remove the lid to the storage compartment and seal it with foam. That gives about 1.5 carryon suitcases worth of easily accessible space. If you get a luggage rack for the back then you can carry as much as a normal sedan.
You could conceivably put in a larger plastic bin and fit some serious luggage but that would take a bit of work. I think if they followed the SW20/AW11 formula for luggage space it would've been much better. I'd buy an SW20 if it weren't so old :/ I recall seeing my first SW20 back in 2002, and I thought it looked old already then.
Old 11-29-2013, 05:28 PM   #11
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
I have driven two of the three. I just do not fit in the MX-5 comfortably so it is a total no-go for me. I have to agree that as a practical daily driver the FR-S is the hands down winner. As a weekend driver, canyon carver or second car the MR-S is just as good if not better. It is difficult for the FR-S to overcome the 500LB weight penalty it bears even with 60 more HP.
The MR-S handles much better than the heavier MR2 MK II and is not as prone to oversteer. I have owned both.
Rampage is offline   Reply With Quote
The Following User Says Thank You to Rampage For This Useful Post:
NWFRS (11-29-2013)
Old 11-29-2013, 06:14 PM   #12
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
My dream is to get a Spyder (we finally get to import them in Canada) and start hunting for a 2ZZ-GE (I've always had a soft spot the the Celica GT-S)
daiheadjai is offline   Reply With Quote
Old 11-30-2013, 10:28 AM   #13
Rampage
Rampage's Avatar
Mine is a 2ZZ. There are two 2ZZ Spyders for sale in CA right now. If you are interested then check out Spyderchat.
Old 11-30-2013, 11:39 AM   #14
Coaster
Coaster's Avatar
Drives: Civic
They fixed that sudden oversteer problem with the next year... made changes the suspension...and wider wheels.
Coaster is offline   Reply With Quote
91 Hardtop Beams MR2 $7000 trdfrs Cars for Sale/Trade 0 06-19-2013 07:24 PM
MINI Cooper S Hardtop for Girlfriend Trojan_SC Other Vehicles & General Automotive Discussions 8 05-16-2013 12:50 PM
**NEW Spider Vision Headlight Tint only @ Billet Pro Shop** BilletProShop Exterior Parts - Lighting 10 03-10-2013 09:24 AM
Alfa Romeo spider will share platform with new MX-5... mines13 Other Vehicles & General Automotive Discussions 22 11-15-2012 11:55 AM
VS MINI Hardtop S Alias FR-S / BRZ vs.... 34 05-30-2012 10:24 PM
