Petrol head life.
Drives: Scion FR-S
Installed side markers now brake/turning/sidemarkets lights dont work! HELP!
I installed my helix side markers just now, after installing one i tested it and it worked. Then when putting the second one it didn't light up. Now even my turning signal lights along with my brake lights wont even turn on. Basically when switching the first set of lights on none of them turn on. Could anyone help please? Thank you.
Drives: Neptune GR86
Check your fuses yet?
Just in case you don't know, the owners manual shows which fuses control which circuits. There are two fuse blocks, one under the hood and a smaller one under the dash. Spare fuses and a fuse puller can be found in the fuse box under the hood.
I hope you get er fixed. humfrz |
Guy on internet
Drives: Slowly
It's totaled...,
Drives: 2005 Toyota Camry
Petrol head life.
Drives: Scion FR-S
trolls not appreciated. get a life.
Petrol head life.
Drives: Scion FR-S
Drives: SSM BRZ
Flip the LED bulb around? Happened to me. Second led wasn't working so I flipped it and it started working.
Guy on internet
Drives: Slowly
lol, ok this might help.
http://stis.subaru.com/proxy/73727/p...0BEV8_2126.pdf |
#10 |
Did you try hooking up the original parts to see if they worked properly after encountering the problem?
#11 |
Drives: Raven Scion FR-S
1. Take led bulb out and replace with OEM if it works then you may have shorted the fuse
2. Put led bulb back in and flip it around if it doesn't go on 3. If neither the fuse is popped and led doesn't go on and stock then you have a bigger problem
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
| Side markers & parking lights don't work | Cajun | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 05-28-2015 04:28 PM |
| Side markers installed & now no brake lights! | Danny | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 11-29-2013 05:18 PM |
| FS: OEM tail lights/side markers and more oem stuff | Baddon86 | Exterior Parts (Aero, Lighting, Etc.) | 1 | 09-09-2013 02:03 PM |
| LED Reverse/Brake Lights With FREE Oem Style Side Markers! | 86_ZN6 | Exterior Parts - Lighting | 1 | 08-25-2013 12:25 AM |
| FS: FRS OEM Tail Lights, Side Markers WTB: BRZ Drivers headlight | BumpersFRS | Exterior Parts (Aero, Lighting, Etc.) | 0 | 08-13-2013 03:45 AM |
