Old 11-27-2013, 10:33 PM   #1
Danny
Petrol head life.
Danny's Avatar
Drives: Scion FR-S
Installed side markers now brake/turning/sidemarkets lights dont work! HELP!
I installed my helix side markers just now, after installing one i tested it and it worked. Then when putting the second one it didn't light up. Now even my turning signal lights along with my brake lights wont even turn on. Basically when switching the first set of lights on none of them turn on. Could anyone help please? Thank you.
Danny is offline   Reply With Quote
Old 11-27-2013, 11:12 PM   #2
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Check your fuses yet?
Old 11-27-2013, 11:19 PM   #3
Just in case you don't know, the owners manual shows which fuses control which circuits. There are two fuse blocks, one under the hood and a smaller one under the dash. Spare fuses and a fuse puller can be found in the fuse box under the hood.
I hope you get er fixed.
Old 11-27-2013, 11:27 PM   #4
pche
Guy on internet
Drives: Slowly
It's totaled...,
pche is offline   Reply With Quote
Old 11-27-2013, 11:37 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by pche View Post
It's totaled...,
warranty voided too.
Old 11-27-2013, 11:56 PM   #6
Danny
Petrol head life.
Danny's Avatar
Drives: Scion FR-S
trolls not appreciated. get a life.
Old 11-27-2013, 11:58 PM   #7
Danny
Petrol head life.
Danny's Avatar
Drives: Scion FR-S
I checked my turning signal and brake lights and they were both good, but the side marker lights were not labeled in the manual. Which is where the problem originated from since when i put the second one in, it stopped working.
Old 11-28-2013, 12:18 AM   #8
congee
congee's Avatar
Drives: SSM BRZ
Flip the LED bulb around? Happened to me. Second led wasn't working so I flipped it and it started working.
congee is offline   Reply With Quote
Old 11-28-2013, 09:05 AM   #9
pche
Guy on internet
Drives: Slowly
lol, ok this might help.
http://stis.subaru.com/proxy/73727/p...0BEV8_2126.pdf
Old 11-28-2013, 09:10 PM   #10
White64Goat
Did you try hooking up the original parts to see if they worked properly after encountering the problem?
Old 11-28-2013, 11:33 PM   #11
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
1. Take led bulb out and replace with OEM if it works then you may have shorted the fuse
2. Put led bulb back in and flip it around if it doesn't go on
3. If neither the fuse is popped and led doesn't go on and stock then you have a bigger problem
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Side markers & parking lights don't work Cajun Cosmetic Modification (Interior/Exterior/Lighting) 20 05-28-2015 04:28 PM
Side markers installed & now no brake lights! Danny Cosmetic Modification (Interior/Exterior/Lighting) 5 11-29-2013 05:18 PM
FS: OEM tail lights/side markers and more oem stuff Baddon86 Exterior Parts (Aero, Lighting, Etc.) 1 09-09-2013 02:03 PM
LED Reverse/Brake Lights With FREE Oem Style Side Markers! 86_ZN6 Exterior Parts - Lighting 1 08-25-2013 12:25 AM
FS: FRS OEM Tail Lights, Side Markers WTB: BRZ Drivers headlight BumpersFRS Exterior Parts (Aero, Lighting, Etc.) 0 08-13-2013 03:45 AM
